Hmmm, thanks fallwind. Well, maybe I'll keep the "free" 7870 and return the other 7870 and call it a day. Time will tell as I have a week to figure it out, but this is XS, so I'm not sure.
depends on how many cpu cores you have available. remember each GPU task needs a dedicated core!
I could test this. You guys just tell me what to do. I read in this thread to not run multiple gpu threads if your usage is ~95%. On my GTX 680, it is at 95% with one thread, so I never bothered screwing around with multiple threads. It currently runs 1 gpu thread HCC, another gpu thread HCC on a GTX 460, and 6 threads of GFAM on the cpu (3770k at 4.7).
I'm gonna' pull the 460 and put it into something else, probably this evening, depending on how I feel (feel like :banana::banana::banana::banana::banana: today, shouldn't be at work).....so, let me know what to do/try.
Thanks.
Edit: I mis-typed....mine is a 670, NOT a 680.
Well my GTX670 produces roughly half what a 7850 does. I don't imagine a GTX680 would do much better. My GTX670 does gain a bit from 2 threads vs 1. About a 4:3 ratio.
My GTX480 is about 30% faster than my GTX680L from what I can see here running 5 WU's on each in the same rig.
I just stopped networking on that rig and checked the times on the WU's, approx 10 mins(GTX480) vs 14 mins(GTX680L) You can also see it if you go in to your WCG page and look at the result details.
app_info.xml for Nvidia that I use, GPU WU's only on that rig.
<app_info>
<app>
<name>hcc1</name>
<user_friendly_name>Help Conquer Cancer</user_friendly_name>
</app>
<file_info>
<name>wcg_hcc1_img_6.56_windows_intelx86__nvidia_h cc1</name>
<executable/>
</file_info>
<file_info>
<name>hcckernel.cl.6.56</name>
<executable/>
</file_info>
<app_version>
<app_name>hcc1</app_name>
<version_num>656</version_num>
<platform>windows_intelx86</platform>
<plan_class>nvidia_hcc1</plan_class>
<avg_ncpus>1.0</avg_ncpus>
<max_ncpus>0.783972</max_ncpus>
<coproc>
<type>CUDA</type>
<count>.5</count>
</coproc>
<file_ref>
<file_name>wcg_hcc1_img_6.56_windows_intelx86__nvi dia_hcc1</file_name>
<main_program/>
</file_ref>
<file_ref>
<file_name>hcckernel.cl.6.56</file_name>
<open_name>hcckernel.cl</open_name>
</file_ref>
</app_version>
</app_info>
[s]Is the space intentional?
line 26
<file_name>wcg_hcc1_img_6.56_windows_intelx86__n vi dia_hcc1</file_name>[/s]
Nevermind. It added another space when I copy and pasted. Is the space in the actual code?
No spaces.
Do you have this in your cc_config to run on both gpus?:
<cc_config>
<options>
<use_all_gpus>1</use_all_gpus>
</options>
</cc_config>
Also, I have to modify the count right? To get 5 per gpu, I need to have .2 as the count, right?
Thanks for the clarification.
I'll play with it when I get home.
I don't know....event log says "not reporting or requesting new tasks"
I'm trying to run 4 on one gpu, and 4 on another gpu.
I read something in Snow Crash's thread about telling BOINC where to get the files or something....but didn't see any further explanation about that.
Here's my app_info:
Code:<app_info>
<app>
<name>hcc1</name>
<user_friendly_name>XtremeSystems Crunches Cancer</user_friendly_name>
</app>
<app_version>
<max_ncpus>1.0</max_ncpus>
<coproc>
<type>CUDA</type>
<count>.25</count>
</coproc>
<file_ref>
<file_name>wcg_hcc1_img_6.56_windows_intelx86__nvidia_hcc1</file_name>
<main_program/>
</file_ref>
<file_ref>
</file_ref>
</app_version>
<file_info>
<name>wcg_hcc1_img_6.56_windows_intelx86__nvidia_hcc1</name>
<executable/>
</file_info>
<file_info>
<executable/>
</file_info>
</app_info>
BOINC defaults to not doing GPU work while computer is in use. Manually set activity to use GPU always and it will start downloading WU's.
Did that already....I don't think that got wiped out when I added the app_info.xml....but I double checked, and it's ticked now.
Edit: Maybe this is the problem?
Attachment 130818
In order to get the application downloaded, I think you need to download at least one WU without the app_info.
I got the same thin when I copied from here but when I copied it from the WCG forum it worked.
try this one
Attachment 130819
Just rename it
OK now I'm confused, I haven't changed a thing but now my log file says "tasks are available for ATI GPU but your preferences are set to not accept them." WTH!
*edit* found a check box on the WCG page to allow GPU units, and it was unchecked. I didn't do that. Set it back to checked. Wacky. Now to figure out how to load down my card better.
*edit2* My card temp barely wavers a couple degrees, but even at 84% load it reports the clocks are still at 2D 500MHz?
*edit3* dang, I'm still on 12.4 drivers :p: That might be part of it. Downloading the latest drivers now.
This did it....sort of. I stopped everything, removed the app_info, restarted everything, BOINC took a minute but d/l'd some new work units (GPU only now), cards only worked on 1 each, I suspended and stopped everything again, replaced the app_info, restarted everything again....all is working now.
Thanks all for your help.
