UEFI at the top and everything below is gone
Originally Posted by
iboomalot
When I try to enter Bios or Q-flash the screen says UEFI at the top and everything below is gone.
Sometimes on reboot the system hangs and restarts in the first 2 secs I think the Bios is corrupt and was going to Q-flash it but won't load Q-flash.
Should I do a bootable USB and try to reflash that way??
That kinda sounds like what happens when i get a boot loop. PC turns on get to that UEFI screen then switches off...then ON black screen ...then OFF...then ON n OFF maybe 4-6 times then it starts as normal. I dont think any bios updates are gona help this situation Gigabyte's Biggest FLAW in designing a board with dual bios. In the coming weeks or days peeps will see the UP7 which has the switch to OFF the dual bios function. This may be the only way to stop any crosstalk between the 2 bioses. If only GB used this on all there boards or stuck with 1 bios that works proper.
After sending my concerns to Gigabyte support on the 21/08
This is the response i finally got today.
Dear Gigabyte Customer
Due to a vast amount of emails received in non-working hours we couldn't reply your question earlier.
In order to help reduce the backlog and re-assess ticket status, can we please kindly ask you to re-submit your question by replying to this email with subject "STILL VALID" if our help is still required.
If you have found a solution to your question, there is no need to respond this mail.
Thank you for your understanding.
Please accept our sincere apologies for the length of time it has taken to respond.
You can also try to contact the place of purchase / manufacturer of your PC / local computer dealer for help.
Please notice you can also find some useful information at our website: http://uk.gigabyte.com
Best Regards
GIGABYTE Technical Support
