Lets analyze this boys
- Kepler does not have hotclocks - Chart has hotclocks for all kepler parts, when Kepler doesn't have hotclocks, check
- GTX 690 will be the flagship Kepler, on a single PCB with dual GPU - Chart has the GTX 690 using a 224 bit memory bus x 2 - check
- GTX 660 will have a (224 bit) memory bus. Not even possible - check
- Stream processors? Really? Cuda core counts - wrong - check
- GTX 680 has a 512 bit memory bus, while the dual GPU version the 690 (GTX 680x2) has a 224 bit memory bus - lolworthy
The kicker really is their GTX 690 specs. According to that chart it has a 224 bit memory bus with 1.75gb of memory times two. Hilarious.
Yep this sounds plausible.
