It seems more a suicide screen than a bench one btw.
some more samsung luv :)
5.1Ghz HT@ 1,425 / 2176 9-10-10-28 1T@ 1,5
http://img35.imageshack.us/img35/8851/sammy3h.jpg
http://img826.imageshack.us/img826/9370/sammy4.jpg
Uploaded with ImageShack.us
Great detailed screens but same size even when "viewed" and can't read the details :( Imageshack sucks man give imgur or another good free alternative a shot!
I'm presently testing 16GB of new 1205 batch from Microcenter on both Lynnfield and Sandy. So far so great tho still early. 2160 9-10-10 1.54v and 2400 11-11-11 1.65v (though on my first run with the latter now and the bandwidth is a lot lower than I expected comparatively so need to keep tweaking incl. voltage). These things sure are relatively painless to work with too.
http://i.imgur.com/cPULR.jpg
Yeah, please do! Like I said there are a few good free options now but I prefer imgur.com. Even gives you the vBCode tags to copy and paste and saves you a step.
1T not working well at high clock on llano also... same as FX it demands much more voltage.
Currently at:
2160MHz 9-10-10-27-40-2t 6-6 rastoras 5 trfc 110 tfaw 24 1.52v bclk 135Mhz
or
1866Mhz 8-9-8-22-30-1t 5-5-4-90-20 1.50v bclk 100Mhz
pics reuplaoded sorry for the mistake !!!
Yeah I can't even break 18K read in AIDA at similar speed and timings on Lynnfield. Hardly unsatisfied with my IMCs ability to reach high clocks though...
Up too 2208 so far still 9-10-10 and still under 1.6v. This is two different sticks of the 1205 as well; sending to a friend in the UK.
http://i.imgur.com/IzooB.png
very impressive stuff! Definitely a good kit for my upcoming Ivy rig.
Got 4 sticks of 1209 yesterday. Much of the same! 9-10-10-28-1T @ 1.525v on the p8p67 pro for one pair, same timings 1.5125v for the other pair on the M4E. Bought from ocuk for £45 per kit.
Got friends over for Easter so wont have time to tweak them for a few days. I have noticed I only need default vccio, vccsa and pch voltages for these compared to my hynix sticks which need 1.1/0.95/1.1 respectively @ 2133.
P8P67 Pro still cant run these stable at 2133mhz using the black slots. Yet to find any kit that will run 2133mhz and now tried Hypers, PSC, BBSE, Hynix and Samsung. Still cant do 16gb at 2133mhz in my server :(.
They have arrived in Europe too.
Here.
Isn't it the same here , or not (pic might be wrong) ?
Yes the stuff from Overclockers is the same I have two kits from there & on the back of the packets it has model: MV-3V4G3 & Model code: MV-3V4G3D/US
Also when you go on the Samsung website http://www.samsung.com/us/computer/dram & click on the MV-3V4G3D kit then full spec it comes up with this pdf http://www.samsung.com/us/system/con...4g3dus/DD3.pdf stating the /us as the model name.
are we seeing good voltage scaling with theses sticks? im considering sourcing a set, and wondering what i should expect at 1.65+ vDIMM.
Nothing extra using 21.33x multi. You'll get to 9-10-10 using around 1.525v, but for higher mhz on Intel you need x79 or z77 chipset. Extra voltage will not tighten timings beyond 9-10-10-26-1T @ 2133mhz.
i'll be looking at z77.
anyone using this with z77 yet?
hey sorry I didn't want to read the whole thread, but you think the 4GB kit would be as good as the 8GB or better>?
http://www.microcenter.com/single_pr...uct_id=0380718
same 30nm process.
Get the 4GB batch 1205 @ MC
4GB X2 or 2GBx2?
and thanks :)
