Interlagos/valencia is normally scheduled for 11/11/11 but it is not an official date.
SourceQuote:
Originally Posted by Phoronix
In some cases the improvements are huge. Should be interesting to see how Bulldozer will turn out in the long run
any truth in this?
http://quinetiam.com/?p=119Quote:
After our own reader-base flagged the matter in comments last week, we began to investigate a rumour that there was a registry patch in the works that could offer a 40 per cent performance increase for AMD’s Bulldozer CPUs.
The issues brought up by the article are true, but I'm not sure if a simple registry patch will be enough to fix it.
Windows 8 employs a new scheduler to better optimize for Bulldozer, and from the developer preview, we can only see a few percent boost in performance at most.
It'd be great if this was true, but I highly doubt it will happen, otherwise AMD would have worked with Microsoft to get the patch out in time for the release of BD.
The increases are truly impressive, but not across the board for the AMD compiler. Furthermore, it may be feasible to recompile your applications when running on a server dedicated to a specific task, thus optimizing the application for the hardware it will be running on and get great performance. But you can't achieve the same thing when you're running Windows with a bunch of closed source, unoptimized games and applications. So as much as the potential performance of Bulldozer is great, it's still not utilized to the fullest due to the lack of OS and compiler (of current apps) support.
I still remember JF-AMD's last post, almost a month ago just before this crap was released:
We are used to this guy's arrogance. He knew about BD's perfomance, and he just played with the fanbois for months. In the end, you get what you deserve.
Funny thing is that people are still looking for magical fixes and other bullcrap. Just let it go guys, BD is a complete failure and you won't change that.
It's official. All those 2012 doomsday theorists are AMD fans.
And in the end this isn't rally iteressting for the people here anyway... most common compiler for the windows platform is the MSVC. Its nice that you can gain some gain, but if you can't get them in 95% of the apps out there what is it worth it?
Intel on the other hand still managaes to get ~5-10% avg ipc increase each generation compared to the previous one in the same apps, so if you run the same apps you actually gain something and you don't have to hope that one dev decides to recompile there programm and also with the right compiler.
Im going to buy one just for cpu-z benching :)
AMD FX-8150 Multi-GPU Gameplay Performance Review
November 03
http://www.hardocp.com/article/2011/...mance_review/1
No suprise there, once you remove the gpu bottleneck (tri sli) BD only sees dust from SB.
Another SLI benchmark set:
http://www.madshrimps.be/articles/ar...#axzz1ceA1SgT8
The BF3 result is especially interesting since the game was chosen by AMD to present BD as an "enthusiast CPU".
We all know the design is broken. It's just literally a matter of what Redbull78 said, "What were they thinking?". They must have known for at least a year that the design was broken. Having said that, I own an 8120 and it's not such a bad CPU.
Give the CPU some time to mature and we'll see how far it can stretch it's legs. :)
BD with different compilers in linux :
http://openbenchmarking.org/embed.ph...ha=830ac33&p=1http://openbenchmarking.org/embed.ph...ha=6fe0918&p=1
Link : AMD Bulldozer With GCC, Open64, LLVM/Clang Compilers
Published on November 02, 2011
Now compare to Sandy Bridge
Link : AMD FX-8150 Bulldozer On Ubuntu Linux
Published on October 24, 2011
Also See : Open64 Compiler Tuning On AMD Bulldozer FX-8150
Yeah, if gaming is your top priority Bulldozer with it's very weak cores is the worst buy for the price. And it's further exacerbated by the fact that most games today are compiled with ICC.
clock speeds are crap in that review, 4.6ghz on an FX-8100 would be a complete waste, and someone would rather disable some cores or go with a 6100 and overclock it higher. it wouldnt be enough to beat a 2500k, but it would bring the gap up way closer is some titles.
Seeing alot of talk about bd being buged and not running a lot of games, even bsoding on some titles.
looks like AMD is cutting 10% of its workforce,according to the Associated Press.
AMD to cut 10 pct of workforce as PC weak
maybe they can put that extra $10 million to good use?
double post, and I only hit the button once...
