Thanks !!! :up:
Hi,
here pixelview gtx 460 1 gb bios. Please unlock it for me.
so fast, thank you.
Is it possible to flash BIOS from 1 GB to 768 MB card?
Not as far as I know. I'm pretty sure you need to use a smililar bios for each (768mb bios for 768mb card etc).
here is my MSI GTX460 Hawk Talon Attack bios (default 811/3900)
I need only GPU voltage unlocked to 1.212, mem set to 4000 and fan unlock
can u mod it for me?
http://www.filefactory.com/file/b488...on_Default.rom
Hi, can you please modifie me a Gigabyte GTX 460 OC 1GB(custom pcb) bios.
I want same stock clocks, 715/3600, but i want modified 3d gpu voltage from 0.9875v(stock) to 1.012v. And let the voltage limit to 1.087v(don't remove the voltage cap).
A friend has a little boot issues.
3d voltage is also the boot voltage , no?
Here is the bios:
would you like non ref card bioses?
Hi.
Here is my Gigabyte GTX460 1GB OC original F11 bios. Could you unlock the max voltage and set the min fan speed to 30% ?
Thanks for advance.
Very fast man but the file is untouched :ROTF:
Could you do ti again ? Thanks for advance.
Can i use the MSI HAWK bios on my standard Colorfull gtx460 1 MB vidcard, or is this bios only for the MSI HAWK cards.
If not ...what is the best bios for me to use on my card ?
Allready tried the EVGA bios, and it worked, but didn't notice any change..
unlock plz..Calibre 460 1 GB def (790/975)
FAN 100% dan vgpu 1.212
http://www.2shared.com/file/TP9v6TuE/gf104.html
Thank you !
Hello All,
Gr.,
Stefan
