Yes I noticed the same thing, glad it isn't just me.
My board, but not my result, cause I didn't take a picture of mine!
http://www.abload.de/thumb/21x226ty0g.jpg
Thanks to RomeoJ!!!
The new ek full board block is out, and looks amazing..
http://www.oxfordgraphix.com/ek.jpg
http://www.ekwaterblocks.com/shop/ek...d7-nickel.html
Wow that looks great. Pity i have already stuck hetpipes back on :lol; :shrug:Quote:
Originally Posted by Pickles24
A few recent updates to Gigabyte GA-X58A-UD7 Living Review:
1) Gigabyte GA-X58A-UD7 - The naked truth
http://www.images.clunk.org.uk/revie...D7/IMG_2928.jp
2) Voltage Measuring Points
http://www.images.clunk.org.uk/revie...IMG_2307-a.jpg
3) 4.4Ghz 21x210 Ram x8 1,680Mhz 7-7-7-19
http://www.images.clunk.org.uk/revie...s/21x210@8.png
Here my highest possible Settings with 21x Multiplier!!
http://g.imagehost.org/t/0177/22300_2.jpg
Oc Nub, as I mentioned earlier I have a ton of watercooling parts laying around and I was thinking of setting up this i7 rig for water. Your temps look pretty good but I see you have your rad pulling from a window ac unit, have you tried running it without the window unit? How are the temps? Here is a list of the parts I have laying around that I was going to throw together :
Swiftech MCP-655
Black Ice Pro II rad (240) or Swiftech MCR220
Old Swiftech Apogee extreme Duty Block (I will buy this adapter)
Large 2 Bay Res
10' clearflex 38 tubing
The only part I would need to buy would be the adapter bracket for the Apogee and a few fittings, I would be in my home office which stays around 68F. In your opinion will I see a noticeable improvement in temps or will my i7's heatload exceed a single 240 rad?
I think it would be worth trying, you could also add the second rad to the loop if need be. I haven't tried a 240 rad so I'm not sure what kind of temps to expect. I am not that experienced at water cooling, maybe someone else will have a better idea what to expect.
I will test after work to see temps with no ac but I believe they were around 10c higher.
Did a quick run when I got home from work. With the room at 77f my temps after 5 passes LinX hit 80c. Normally the room isn't this warm but the wife is has the heat blasting.
I will be going back to my UD6 board tonight. I know this is a faster platform but I miss that board, and the platform. There are no games out that I like anymore so I have no need for cf or sli, and for a single card I prefer my UD6-870 rig.
can some people perhaps confirm that the waterblock on the ud7 is copper and has 3/8" fittings please?
cause I'm finding some contradicting statements... (7,5mm vs 10mm outer diameter fittings)
In the gigabyte manual:
http://europe.giga-byte.com/FileList...x58a-ud7_e.pdf
This implies fittings with a outer diameter of 19/64" (or more likely 5/16", since I don't think 19/64" exists)Quote:
For the waterblocks on the North Bridge heatsink, we recommend tubes with inner diameter of 7.5mm and outer diameter of 10mm
In Supershanks review:
http://www.clunk.org.uk/forums/revie...html#post79973
this clearly states 3/8" as outer diameter of the fittingsQuote:
The waterblock is copper on the UD7 unlike the aluminium ones used previously, which is a plus as most people use copper blocks, so you won't be running nixed metal blocks. There are no alternate barbs, the fittings are 3/8" (10mm) so if your using thicker tubing you'll need to use something like PrimoChill Reducing socket 13mm to 10mm (1/2' to 3/8').
please also mention in which country and when you bought the mobo (in case there are differences)
thanks!
Finally stopped wining :)
Playing with different C-states (disabling the C1E, and enabling "C3/C6/C7 State Support") helped lowering the intensity, but couldn't stop it totally with LLC= "Level 2". It was LLC= "Standard" that could finally shut her up, totally.
In my experience, with LLC= "Level 2" the lower Vcore results in more wining (more intensity in high-pitch sound). In my 2 different 24/7 setup, the @4.22GHZ(222x19) 1.2v has been wining much more than @4.51GHZ(215x21) 1.34v. Also, lower-Vcore = more-wining.
The combination of LLC= Standard + disabling the C1E + enabling C3/C6/C7 State Support, has stopped it totally independent of the Vcore. :)
@ OC Nub thx man, I went ahead and ordered the block adapter and fittings today, my room stays cool so I should be fine and like you said I can always add the second rad :up:
@ Mastakilla, I was curious so I tested some clearflex 60 I had which is 3/8 ID and 5/8 OD and it went on without too much force but did grab so with a clamp I think 3/8 ID is good but 5/16 would be very snug and possibly a better seal.
4.83G pass linx 50 run on water :rofl:
http://i645.photobucket.com/albums/u...g?t=1264515192
dude, I have a really nice w3520. i'll trade you for that wimpy i9...
LOL, that wimpy i9... is actually a Intel 32nm Xeon Westmere DP 3.20G , and it isn't exactly cheap.
Good job, this looks good. These 32nm Quad seams to handle much more Vcore with less heat. :)
I've been hoping that some batch# of these 32nm Quads can hit 5GHZ for 24/7 use on air/water, and this is a really promising start .
I purchased my UD-7 from newegg a US online retailer.
Some quick tests to see how it works with LLC= "Standard" and looks good.
It is a huge Vdroop(compared to Level 2), Vcore= 1.30625 (BIOS set) ends up as 1.24v/1.21v (Idle/Load). But I'm keeping it, not only because stopped wining, but seams to be running stable with 2 higher BCLK:)
PCIe = 103MHZ, not only boots with BCLK224, but also seams to be stable roo:)
w3520 @4.25GHZ (224x19) 1.21v :cool: 30 min OCCT stable :)
http://img.techpowerup.org/100126/Ca...8-20100127.jpg
PUMP IT UP TO x21 BABY!!!
LOL, I would love to, but I don't dare to try it. My air cooling would have some major objections.
I couldn't get it it over 4.5GHZ(215x21) 1.34v yet (not without breaking my own cool&quiet requirements).
Woah so increasing the PCi-E clock helps the overclock? If so I think I might have 4.5 GHz in this chip.
I just ordered some reducing sockets (1/2' to 3/8') from DD, they should be here tomorrow, and I'll post how they do with the stock block. I am running a X-Flow Black Ice Pro III with a single bay res, and room temp around 65f. Should be plenty of rad for the nb and cpu. If not I have another Black Ice Pro single 180mm I could add into the mix.
