Hey guys and girls... can I join your club?
batch number is 3912A859
Enzo78,very nice.great vcore for 4.66Ghz.thats one of the better
39 chips ive seen.thats the kind of vcore you'd expect to see with 38 batches:up:
Always nice to join a cool club ;)
From what I have read on these here forums is that its the strength of the imc in the chip that allows higher bclks? I can boot into windows at 225bclk 1.34qpi/vtt so there maybe abit more in the chip yet.
New submittion @ 1.36v
http://img29.imageshack.us/img29/491...120mb13.th.png
Same CPU as above. :)
I can't believe there is only a single socket 1156 CPU :eek:
Makes me feel so much better about my 4.82ghz quad prime stable (30min++) i7 860 @1.44v; good 24/7 cpu. Only does 4-5 passes of Linx though so unfortunately I won't be joining the club. I was thinking about spending a bunch of time tweaking and getting a #1 spot for the i7s (would be hilarious to see a 1156 cpu as #1), but the recent submission of 4.84 is definitely not something I can surpass. 4.82 would already be at my limit for 20 passes of linx.
I can't believe I got such a good CPU. This chip + more capable hands + LN2 = all CPU 1156 WRs.
I would need a better mounting mechanism for my single stager. I am using socket 775 mounting for 1156! Yes, it is as horrible as you are imagining it. Backplate had to go and a few things had to be made on the fly and the contact still isn't good. Temps as high as 10C when Linxing with -35C evap temp.
told ya i be back:D
can only run 4gb i have 6gb in but windows won't see 2 after 225blk
cooling mcp320+gtz+jeep heater rad+655+some cold air
batch #3849B018
i'll be back :D when i sort out cooling +ram issues
and go higher;)
Well finally i can join
changed rad and block and can linx at ~1.4vcore at normal ambient temps 22 to 24C, before i had to hit 10C AC to the rad
either way temps are high but system holds it before it was a < 1sec BSOD :)
http://img12.imageshack.us/img12/408...1600linxxs.png
Cheers guys :up:
Sergio
zsamz,wow!! very nice
andressergio,nice.looks like the USB3P is just as good as the UD3P
thanks man
andressergio lookin good:up:
with the pi max i did on rex was 1940mhz 6-9-8-24 stable over 1940 not even volts help
and i did it with e8600;)not a quad
i put in 6gb windows sees 4 i put in 4 windows sees 2:rofl:
i'm not goona run linx with 12gb:rofl:
tried primin n was a peice of caked compared to linx:rofl:
hey i'm game stable too:D
i thought the minimum was 2GB installed?so that run should just fine.
on my i7-920 i only had a 4GB kit on hand and it was ok.i picked the
max memory setting and it was just over 2500 and it was ok.
You must have at least 2GB of memory installed in the system.
Screenshot must show a CPU-Z window with 4.5GHz+ frequency.
Screenshot must show a LinX window (max memory settings, click "All" button, or pick the last memory size option from the drop down menu, the "All" option is highly recommended) either running the 20th+* loop with no errors, or with 20+* successful passes.
dont worry you can still do 4.8Ghz,i can help you with that problem.just send me 6gigs.problem solved:rofl:
