if someone who knows to put all the link from bios evga E760?
thanks!
thanks!
Here it's the last BIOS:D
You can also check evga's forum:rolleyes:
what is the diference evga x58 "141-BL-E760-A1" or "141-BL-E760-E1"?
A1 -> America
E1 -> Europe
With an A1 you won't be able to RMA in Europe (in case someone imported such a board).
Is there big difference between 760 and 759?
Which one is better?
If you are going to use 3 way Sli, take 759 with NF200 you can run 3x 16x, otherwise there is no diffrence.
you can also check post no 1 of this thread
http://www.xtremesystems.org/forums/...d.php?t=224806
100 percent stable
with these settings. I would want to turn HT on but don't want to run my chip hot.
What do u think? any input would be appreicated.
http://img195.imageshack.us/img195/3...forstable2.jpg
Plenty of room to go.
Is there big difference between Gigabyte extreme and EVGA classified, when I use unlocked multi CPU?I now that classified is good for high BCLK, but price difference is quite big.Extreme is 195EUR and Classified 300EUR.
Is this money worth it?
A very nice chip you got there! I run 4.2ghz 1.32vcore and my temps in linx go above 90C.. :p:
But FYI I've had two 920 chips, and both have been always like 88C in prime. Never had any problems and neither of them got burned or otherwise damaged. Just try to keep them below 85C if you can.
Keep pushing it!
anyone actually know what the extreme cooling jumper and bios modes actually do to the board technically?
G80
unless you do extremecolling i'd say the classified is overrated, yes it's a good mobo but it have it's flaws too without mentioning the hefty price tag
What's the highest bclk you guys can boot up at?
A new BIOS will be released early next week that makes some improvements to the bootup bclock.
Are there any known issues with the 950 DO CPU's ? Our board is limited at max 230Bclock We tried 3 CPU's already ; 1 X 3540 and 2 x 950's. Weird thing is with the 950's we cannot get the OCZ Blades anywhere near stable above 900mhz, while we benched with the 3540 around 1100Mhz dead easy.... Rams are still okay as they perform on S775 and P55 platform...
who knows if the second 8 pin to cpu is necessary το bench with ln2?
i want to answer only if knows very well because i want to change my PSU ,its tagan 1100 and i put it one 8pin and one 4 pin!
thanks and sorry for my bad english!!
I had the same thing happen with my 950 while using the x24 multi which was garbage
x23 http://valid.canardpc.com/show_oc.php?id=598857
Also did 258 bclk low muilt :up:
All 23X Multi used Sir Shamino. Gamer, BLind Ripper and Massman topped all at 230Bclock with the Xeon and 950 CPU's... With the 950's the OCZ BLades were not as stable as with the W3540 CPU... One has a weaker IMC but Blind's one is pretty good... I will drag Massman in here :D
