final air runs for the night on this board, ill try bios g13 tommorow 'I heard its better'
and setup for subzereo :yepp:
http://img515.imageshack.us/img515/6230/06285kcr9.jpg
http://img12.imageshack.us/img12/8708/32233ou4.jpg
I don't use this utility to clock, only to show settings.
This is what I run 24/7
Attachment 94442
how do you read voltages?
you cant really compare bios or windows meassured voltages or the voltage settings in bios even since they fluctuate and arent 100% accurate. Plus each board reads voltages differently :)
Sme read vtt at the pwm, some between pwm and socket and some inside the socket. the differences can be quite big just from where you read voltages. Imo the best spots to meassure voltages is as close to the parts they are powering as possible, cause thats what matters. On BloodRage the voltage pads are doing a pretty good job, especially for vtt.
the vcore and vtt settings and readings in the current bioses of BloodRage are not accurate and a bit off, we are working on adusting them now :)
@saaya
Do you now the Date of the New Bios?
@dengyong
Itīs the same Settings but without Turbo Mode. And i don`t need so much VTT. Is this right that VTT is only for OC the Memory and the Uncore?
http://www.abload.de/img/screen000003ehb.jpg
Anyone know where one can buy a Bloodrage Rev 2? Still nothing at newegg..
how ya know what rev board ya have got?
My problem was that i doesnt disabled PPM :rolleyes:
OC with EIST/C1E goes up to a BCLK from 166,above i must disable it.
Would be very nice if this with a upcoming Bios also run at high BCLK :up:
So here is my new bloody friend :)
http://www.abload.de/img/img_31621024x76877x3.jpg
http://www.abload.de/img/img_31411024x76816lp.jpg
The best i did on air (TR120 cooper)
http://i43.tinypic.com/2epsnd2.jpg
http://i41.tinypic.com/rvbmtj.jpg
http://i39.tinypic.com/10z4qax.jpg
i think 219 is good
219 is very good. What is the batch no. of your processor?
Anyone using these OCZ Platinum 6GB (3 x 2GB) 1600 (PC3 12800) CAS (7) on this board? Any problems?
What VCore and VTT did you run to get the 4.5 and was it completely stable and with what temps? The reason I ask is that I can reach 220 BClock on my 920 but when I up the multi it becomes unstable.
why do you have to disable EIST and PPM? without it you wont be able to use turbo... if you want the cpu to run at full speed all the time set cpu turbo to always on :)
wow... :slobber: ...beautiful...
rbuass, very nice! :toast:
try setting vcca 1.1v higher and play with the other chipset voltages, you might be able to get some more out of it :D
whats the highest you can boot at?
whats the max 3d stable?
nice! :D
Thanks SAE :) The Masterkleer in your Sig is the same im using here :up:
Also thanks :)
Really dont know what was wrong here,but i can use it now all the time :confused:
With Turbo CPU-Z and Everest shows the 21 Multi but the i7 Turbo Tool told me around 20,7 under load.
And the VCore is totally different with 21x191,19x211 is ok.
I have a problem with my case, for the power led it is a 3pin pin connector. 2 wires on each end meaning the middle pin slot is empty. Where do i plug this in so it works properly because according to the manual it should be a 2 pin.
