1307 is awwsome thank's ketz it's beautifull a have 250 more points in read 600 in copy 300 in write nowi will try it in overclocking :) beautifull
Well, took the plunge and flashed the 1306m R2 for the P5Q-E. No problems so far, will test later on.
Oh... and no boot logo here either lol.
They fixed it,,,,,, WOOOOOOT.................... Apparently I was right sorta.. The new revisions didn't cooperate with the Q9450s as they should and mine just got fedup with it but, the problem is I am at work right now and can't reach my PC to try it out yet. I uploaded it here for everyone.. Cheers. Ket you can mod it while I'm at work or even see what they cought that was screwing it up maybe if you want. I asked the tech to ask them what is was exactly but he said he might not get an answer but, it deffinately had to do with my CPU he said.
P.S.: It is 1403 BIOS.
Investigating 1403 now. Truehighroller, did you happen to ask if they will be including the fix for other P5Q models as well?
Well I just tried it and it didn't fix it. :(
Edit: did you ever watch my video?
Nope it never worrked right for me always taking ages :\
my new pq5-e from newegg is a rev A3 on the north.
so far all bios work fine for me on loadline. without it i get massive vdrop/droop. with it on.. it over volts alittle on load.
I wonder what changes were made... wish asus would tell people stuff like that. Usually hardware revisions fix or improve things quite noticably.
Well I am packing that video for you so you can actually just download it instead of trying to stream it. What ftp program are you using?
Ok try this Ket,
I tried it and it didn't work with the link,,
I put it on the server though. Do you still have the server info? You can jump on the server and download the .rar version.
1307 is beautifull :) thank you very much :)
waiting for 1403 best as allways :)
maximus 2 formula is p45 chipset yes? is it possible to insert in bios same overclocking features as maximus on p5q non pro? and memory table of course like in 1307 :) this is beautiful i hope that soon it will be possible to crossflashing p5Q non pro on maximus 2 formula :)
Tony, I'll try to drop you a PM in a day or two, if you haven't got a PM in a few days just remind me I'm pretty busy atm.
Vazovskiiii, What your asking can be done, but would likely require a lot of work and BIOS re-programming on top of careful cross-referencing. For these reasons there won't be a "incredible hulk" BIOS for the P5Q series, I don't have the time, nor do I possess all the tools Asus use. Of course, if a company were to pay me *cough* Asus *cough*, then it could be a different story.
Woot ! When you say customized you also mean optimized timings or rated timings from OCZ?
Sadly i dont have any other platform to test them so... i'm waiting for an update of spdtool to recognize P45. I hope configuring timings from SPD bytes will fix stability problems.. Does EPP contains more settings than SPD? Or it's just a marketing renamed SPD?
EPP is a laughable gimmick. About half of the speed data has been reconfigured. Heres a quick rundown of changes;
- Added 800MHz frequency to speed data
- 2nd speed profile is 533MHz, 3rd speed profile is 400MHz
- Auto Timings @ 800MHz = 5-5-5-18-42-42-4-8-4-4
- Auto Timings @ 533MHz = 4-4-4-12-28-28-3-6-3-3
- Auto Timings @ 400MHz = 3-3-3-9-21-21-2-4-2-2
Now, the more technical stuff.
- CLX-1 @ 533 is 0.50ns
- CLX-2 @ 400 is 0.50ns
TRP = 12.50ns, TRRD = 10.00ns, TRCD = 12.50ns, TRAS = 45ns, TWR = 19.00ns, TRTP = 10.00ns, TRC = 105ns, TRFC = 105ns.
Naturally, I have tested this speed file myself on my OCZ2N1066SR1G kit, all works perfectly. These timings offer an extremely good balance between performance and compatibility. EPP profiles have been left unchanged. Test platforms have been Asus Crosshair, Asus M2N-SLi, and Asus P5Q Pro.
I give effective frequencies not "halves".
Because intel chipsets need a higher TRC vs. AMD chipsets for maximum compatibility, stability and for OCing. Not all boards offer the TRC value in their BIOS (such as the P5Q series) thats why I set it higher. Its RAM 101, surprised you wern't aware of this :eek:
Here is a (and possibly eagerly awaited) modded version of BIOS 1403 for the P5Q Deluxe. No updates for any other boards as Asus haven't released any, I keep checking various FTPs and a few other places, nada. Perhaps truehighroller can ask Asus when the other P5Q boards will get the updates the Deluxe has. (hint hint, nudge nudge :p: )
P5Q Dlx mBIOS 1403
