Good job, although like the EK supreme it looks a bit clog prone with the wrong coolant. Probably a good bet to stick with fuzion or apogee gt/gtx if you are using any dyes.
how come the q6600 is 10c less then then the q9450?...when the q6600 has more volts and is the hot unredisgned quads...
Nice to see some figures finally..!!
Anyone notice the 30C ambient if thats what it says......my french isn't that good something about "entree et debit", enter..??? assuming thats the rad air intake temp...???
Seems a high ambient to me...??
So should expect lower temps than those shown..... as well..??
No hang on just saw the eau bit, so thats water in temp then I take it...??? and the "debit" must mean flow rate at 1.5GPM, so is that 30C water in temp and flow rate of 1.5GPM...
Never mind its still a high restriction block meaning I'll need to add a new pump as well..... :(:(
I think I'm going to go with the XSPC X20 Delta V2 for now, as its quite cheap, low restriction, and gives pretty good results....... and when I replace my mobo in a month or so maybe I'll add a DDC 3.2 and XSPC top, and then look again at improving the block depending on how well the Phenom will OC on the new SB750 mobos...
Glad I waited though...!!! Look forward to seeing some results when someone gets this though...!!
Can I also just go off topic for a second to say how sad I was to read that Martin is bringing his testing and reviewing to a close....!! I have only recently come across some of the results and his webpage and all I can say is what a fantastic contribution he has made....:clap::clap::clap:
I needed look no further than his website to get all the information I needed...!!!
Thanks for your hard work.... I'm looking forward to seeing your QC CPU Block results as well.!!!!!
It's 30C water temperature^^
I know it looks like a 5 year old did this but....here's approx where the GTZ fits in thanks to Martin's Thermalright test chart.
http://img185.imageshack.us/img185/2054/flowan1.jpg
Nice, I didn't think they were allowed to release that stuff yet....:eek:
Very nice though. I love the new design, it's very different and very unique...that's hard to find these days.:up:
The only thing I'm not understanding yet is the comparison appears to be comparing at a fixed GPM.
Doesn't comparing C/W vs flow rate is a good way to penalize the lower restriction blocks and not a real world results comparison? Cathar mentioned this out a while back, to do it right you would compare pumping power instead of flow rate on the x axis.
Or you could calculate the actual c/w based on the pressure drop curves for each block compared and use the appropriate c/w value for the returning flow rate you would expect.:shrug:
Regardless, it would be a good comparison for the Supreme as it's probably higher in restriction.
Very interesting, perhaps we have a new king?...:D
Good times!! the competition is getting strong these days!..
Ahh... internal shots, finally! I don't believe those numbers yet, though. That would be a spectacular improvement in cooling.
Man, I want to get my hands on one of those.
I am sure it will be a good block. Honestly, I wasn't hoping for more of a change in the internal design, something revolutionary, something no one else was using. To me it looks like a D-Tek Fuzion top on an Apogee GT base. Granted, they did add the channels on the outside area, but how does that help cool a quad where the majority of the heat is in the center, i.e. the reason we bow our blocks. Also, in the looks department, it looks like a D-Tek to me, IMHO. It would have been nice to see another vendor take a chance on making their block stick out, like the Enzotech. Again, just my opinion.
Anyway, from a cooling standpoint, I am sure it will be just as good as the Supreme and D-Tek. Swiftech makes very good products.
Utnorris
Now that's more like it. Internal pics and even some preliminary testing :up:.
Can't wait to see these finding their way into our good homes... :D
Im guessing this is a dual pump block with todays anemic ddc 3.2's lol
I'm just really happy to see some manufacturer tested data. Happy to see it and would encourage more....that's awesome!:clap:
I personally would like to learn more about how they do this sort of testing. All the typical questions come to mind.
- Is multiple mounting done when this sort of testing takes place?
- What sort of mounting pressure is applied?
- What sort of thermal compound is used and what method of application?
- Is the processor IHS stock or lapped?
- On the fuzion block was the quad nozzle or any nozzle used?
- The temperatures we're seeing, are they an average of core temps, or some sort of probe inserted somewhere?
- If the temps are core temperatures, which software and how long are these logged for and averaged?
- What is being used to "Load" the processor? Is there some sort of warm up time that's standard.
- What does the 30C mean, is that water temperature?
We're all struggling to figure out the best way to test these things third party, it would be awesome to better understand how it's done by the industry.:up:
Just getting ready to start in on my second round and trying to sort out the testing methods...
Martin PM me your email address plz, you apparently are not accepting PM's...
Ok People, sorry for disappearing for a week, but it's been quite busy around here.
1/ I owe the XS members an apology for jumping the guns a bit concerning product release. We expect to start shipping to the dealers next week.
2/ The information presented by cooling masters coming from unpublished data on our site is unauthorized, unnoficial, and incorrect! It WILL change at the time of release. For example, I can tell you now that pressure drop curves in particular are completely wrong. I am asking members of XS and readers to disregard any information that is not officially published on the Swiftech site.
Thanks for the update and clarification gabe, we all appreciate it.
