Thanks. :up:
Can some more people chime in on the Temp situation with their 9850's please?
I would post my temps but they equal on load what you guys have as idle ;)
3.4GHZ today i was idling at 20C and 43c load
what ambient temps
Uh hey I disabled Sam2008 TLB Fix and although this is B3 Stepping I still get 200-500 with the TLB Patch Enabled:shrug: Is there anyone that can confirm that this is happening to them as well? Is that normal? Ishould not think so considering it is a Phenom B3:confused:
Winrar bench??Quote:
1.3V is used as the default on the DFI M2R here too. The GBT780G mobo chooses 1.25V as default but that board seems to handle voltages different. With higher multis i had up to 1.44V usage shown in CPU-Z load whene it was 1.28V in idle and 1.25V in the bios.
NBVID can be higher than CPUVID had my BE9600 running at 500MHz with 0.7V while the NB was at 1.8GHz at ~1.05V. Why do you not recommend lower CPU VID's than NB VID's? Have there been issues?
There's something wrong with your board DFI based BIOSes in pretty much everything including temps. You can see it in justaposts' ss of different BIOSes :p:
CPU diode which EVEREST/BIOS can read will never (plus zero) be higher than CPU core temps. Usually there's a -10C difference for it. Look at mine for instance or of those on other boards unless they've screwed the readings up by adding offsets.
65C load... that's high, but that's what stock cooler gets at 30C heatsink ambients, 45min load and no TIM.
But I get confused because of the lack of details you guys give when you ask qs :shrug:
In Manchester where Tony is, they won't be much different than 15-25C at most.
MSI and DFI have not disabled TLB from bios with B3, you still have to apply a fix. I have reported this to DFI and to AMD, we wait for a fix.
Being real honest the DFI bios has many issues, i have a few end users now suffering from the flashing cursor issues, tRFC non detect etc so we wait on a fix.
The board with the lowest amount of issues (without testing the asus yet) is the Gigabyte DQ6, it just needs separate NB VID and it would be awesome.
The MSI is clocking good on the latest 1.4 Bios apart from the TLB annoyance.
Ambient water temp is between 8 and 14C dependent on how cold it is out side on my water loop.
BIOS P0J doesn't apply the TLB fix by default for MSI Plat. Tony ;)
Official releases 1.3-1.4 do but the official ones are quite poor for oc but better in stability/compatibility.
EDIT: yeah look to your OS
well, those temps were the same that HWmonitor read as well as Everest, my temperature sensor is also reading roughly 3 degrees celcius below what these programs are reading (its always a little lower) so im quite sure its right. why?
and im using 4x1, i havent done much tweaking with the system since i put the phenom in as i installed the phenom about an hour ago... heh
WEll, you guys are having some decent fun with your Phenoms!
mine still won't post on a 14 or higher multi! no matter how cool it is.. God damn. I'm running out of possibilities.
Running under water?
My Phenom @2,5GHz and 1,3v is under water with load temps of 57c. Read by Abit EQ and in bios. Hwmon + everest reads 30+c and AOD reads 25c..
Quite a lot of different temps. But I'm thinking the first one is the closest one.
That's why :)
Let me know how your dominators do. I've ordered the 2*2gbs. (and I know they use different kinds of ic of course)
OK now this may add clutter, but heres what i posted in another thread about what ive done with my phenom... wasnt much, but it helped.... im also using air cooling with an Asus Arctic Square (works very well =) and arctic silver 5)
now... i would deffinately recommend the dominators, before i got my phenom i had them running at 1000mhz at 4-4-4-12 @ 2.2v with my 6400 BE. i have yet to push them with my phenom tho. but i will in time =)
Ahh I see :D Maybe I have to lap mine too :)
heh, lapping only really makes maybe 2-5 degrees of difference... its not gunna make your 57 degrees drop to 47 degrees load like, say, mine. odd that your W/C is that high. whats your idle temps? im sitting around 29-31 when at a 3.0ghz OC
I don't run SP1 on vista, so its not the OS
Boot open AOD, its yellow, bench, take scores, open AOD, set red, bench see increase
Simple way of testing me thinks
Go to bios, set enabled, go to vista..AOD yellow.>
Go to bios, set disabled, go to vista, AOD yellow
DFI
What am I doing wrong here?
