DaLiu, you may try these if the board still works, i can see some damaged lines over there.. You should try it anw.. :shrug:
vNB 1.4
vpll 1.54
vfsb 1.2
vsb 1.05
cpu gtl x0.67
nb gtl x0.67
vNB 1.4
vpll 1.54
vfsb 1.2
vsb 1.05
cpu gtl x0.67
nb gtl x0.67
reading off each of the boards data strip ;
old bad MoBo = 000-C838679-00483-80-MIB350-802-0219
NEW MoBO = 000-C848DKJ-00952-80-MIB350-803-0308
SOO This is a newer verision than the DEAD MoBo
This will be interesting to see what they send back to replace the old bad MoBo
== also on the old MoBo = the Q connectors some of the outputs didn't function ,I can add that to also the #1 PCI slot shorted out
I just recently bought this board along with a Q9450 and TRUE. Have not ventured into overclocking yet. My temps with RealTemp at idle are 29/29/29/32 and at full are 39/39/39/42. I have not calibrated RealTemp yet, but do these sound ok?
Regarding the voltage settings above, what does cpu gtl x0.67 and nb gtl x0.67 do exactly? This is my first Intel based board in a long time, so I'm still learning. The cpu voltage is not shown in the above, is that correct?
this is the strip of data #'s right at the Floppy drive plug in on the MoBo just to left of of the ATX power input the old MoBo was made in Taiwan & new MoBo made in China all part#'s on the outside of box are the same
the New board Runs great ! i love this board .. i can't wait till the other board gets back to me hopefully I get another new version also
My board is working, i just plagged everything and start from first button. I need to reinstall the windows because my XP is a mess, i just unistalled all old 680i drivers from nvidia and installed Intel(R) Chipset Device Software 9.0.0.1008 but is a problem when i try to install Intel(R) Matrix Storage Manager 8.2.0.1001, some error that my computer doesnt meet the requirement, any idea why this errror show up, can be because i disable JMicron PATA Controller in BIOS, im using all my devices on SATA, 2 HDD and 2 DVD. Is my first board with Intel chipset so any recommandation will be good. Thank you guys!
speaking of reinstalling windows, anybody with older intel chipset did reinstall or just plug and pray? :)
Can you tell me please your temps for NB in full load, lets say stress with Orthos?
How did u setup this options in BIOS:
CPU Spread Spectrum
PCIE Spread Spectrum
DRAM Static Read Control
AI Clock Twister
AI Transaction Booster
Last thing, please recommand me how to stress my CPU, looks like with Orthos i need to start 4 times the program.
Edit later: Looks like with 4 Orthos is not working, some warning message: WARNING: Affinity Mask: Process: 0x2 Sys: 0xF, but i get the same warning if i use only 2 Orthos with affinity set it on 2 cores. So i need some advice how to stress my CPU?
There is a program called MCHTemp which can measure temp of Intel's NB
http://cp.people.overclockers.ru/cgi...MCHTemp101.zip
Intel MCH chips do have internal digital temp sensor which can measure temp beginning from 50 C. Anything less than 50 is not shown in the program. The program really worked for me on P5k Premium (P35). On RF i saw temp over 50 C only once.
What shows bios (and other programs like everest, etc) is received through sensor which resides NOT in the silicon but somewhere on the PCB. MCHTemp gets its data from the digital sensor of the chip (the way Core Temp gets data from digital sensor located in CPU). MCHTemp reads temp directly from chipset. According to author (and intel documentation he refers to) this chipset DTS work only starting from 50C.
Supported chipsets: P35, P31, G33, G31, Q35, Q33, X38. X48 seems to be supported for me. The temp measurement is very accurate, as soon as i increase vNB or switch off fan temp MCH increases.
Hi,
I have some questions on this board:
1- can I use the black Pcie x1 (PCIEX1_1 on the manual) with all pcie x1 cards or it can be used only with the supreme FX Audio card?
2- are the PCIEX1_1 and the slot PCI1 too near at ram slot?
Regards
Ugo
I got random BSOD running Prime95, everything looks just perfect for 40 min and after that just a fast BSOD. I tried all kind of settings, doesnt work for me to overclock this CPU, anybody please can help me with some good settings to overclock a Q9450 to 3200 Mhz (400 x 8) or to 3600 Mhz (450 x 8). Thank you!
Hello all !
I actually need some :help: for o/cing the Rampage Formula.
I'm nearly getting MAD about this mobo, for the following reason :
- I have random "DET RAM" at startup for every o/c i've tried
My specs :
- Rampage Formula (BIOS 308)
- Intel Q9300
- 2 x 1GB Crucial Ballistix PC8500 (BL12864AA.16FD5)
- Corsair HX 520 PSU
- 8800 GTS 512
No matter what parameters (even for softs o/cings) I set, as soon as its not stock settings, I can have a random DET RAM at startup (cold boot or reboot).
I've even tried the cpu level up and Super Mem Profile (which apply an auto o/c based on your specs), its all the same (random DET RAM).
The thing is that - @ stock FSB, with stock strap (here being respectively 333Mhz and 333) - , I can run the memory at 667/800/1066 using the appropriate dividers without any DET RAM (this means the memory's not faulty), but as soon as I raise up the FSB..............a DET RAM can occured at startup.
Example of an o/c profile that is 100% stable (hours of prime etc...) but that leads to random det ram at startup :
Any help appreciated :wave:Code:- Ai overclock tuner : manual
- CPU ratio setting : 7.5
- FSB frequency : 400
- FSB strap to North bridge : 400
- PCIE frequency : 100
- DRAM frequency : 800
- DRAM comand rate : 2T
- DRAM timing control : manual
- CAS latency : 5
- RAS to CAS delay : 5
- RAS precharge : 5
- RAS active time : 15
- RAS to RAS delay : auto
- Row refrsh cycle time : auto
- Write recovery time : auto
- Read to precharge time : auto
- Read to write delay (S/D) : auto
- Write to read delay (S) : auto
- Write to read delay (D) : auto
- Read to read delay (S) : auto
- Read to read dealy (D) : auto
- Write to write delay (S) : auto
- Write to wrtie delay (D) : auto
- DRAM Static read control : disabled
- Ai clock twister : lighter
+ Tansaction booster : manual
- Performance Level : 12
- CPU Voltage : 1.25v
- CPU PLL voltage : auto
- North bridge voltage : 1.25v
- DRAM voltage : 1.8v
- FSB termination voltage : auto
- South Bridge voltage : auto
- Loadline calibration : disabled
- CPU GTL reference : auto
- North bridge GTL reference : auto
- SB 1.5 voltage : 1.5v
- CPU spread spectrum : disabled
- PCIE spread spectrum : disabled
E8500/QX9770 + cascade benching here with all the settings provided. (text in Finnish, but ain't that important :D)
http://img228.imageshack.us/img228/2606/01thumbwt9.png
I have one big problem regarding overclocking and prime95. I tried all kind of setting to reach fsb 400, 425 or 450 but everytime when i stress with prime95 on BLEND i take BSOD sometimes after 40 min, sometimes after 2-3 hours, is random, but if i chose Small FFT on prime95 i can run 10 hours without any BSOD. Any explanation?
DaLiu, have you run Memtest on it?
performance level 12??
and i thought i was nuts....
thers no gain then on ure rams.. infact might be worse than stock
try this
fsb strap at 333
mem at 800mhz
pll at 1.6
nb at 1.35
ai clock twister at moderate/strong/very strong
transaction booster performance level at 8
fsb termination at 1.2v
gtl at 63 for both nb and cpu's
Not with this motherboard but i changed 2 types of ram to be sure the ram is not the problem and looks like the ram is 100 % ok, i just finished 2 hours session of OCCT, no problem, 8 hours of SMALL FFT, no problem, the only problem is when i run BLEND on Prime95, random BSOD.
