Mr.Q: Yep. I thought you'd benched 3GHz too Mr.Q? :confused:
I hope those temps are chilled watercooling or they're being reported wrongly. Phenom 1.2V 1.20VID idles near 12C above ambient with the best air HSF and some deltas or with medicore WC. With voltage and VID increase TDP shoots up v.quickly and at 1.53V 1.25VID, you'll be seeing high temps. ;)
Not quite 3Ghz no, I've a 3003mhz screeny from AOD but it was so unstable half the screenshot is corrupt, as in the bottom half is pure grey. Max verified so far is 2948mhz using cas 4 on mem or 2937mhz using cas 3 on this A-data DDR2-800.
