True. My FN122 is a Gale... I have tested the San Ace 1011 and the FM 121 side by side on my PA160 test rig and the San Ace far and away is a quieter and better performing fan at any speed. I probably have a half dozen FM 121 fans mounted to various heatsinks and at the time they were the most highly recommended fan for that use. However at anything over about 1300 rpm they make my ears ring after a short listen.
The San Ace I am using now have a lower pitched sound and when run around 7V are more than adequate and much less annoying than just about any fan I have used.
I have a fairly large collection of SilenX and frankly I think all the SilenX hate is a bit overdone. They are lightly constructed fans that look nice and produce reasonable airflow for most applications. They are expensive. The only downside I have to these fans is the oil in the bearing is contained merely by a self adhesive sticker--if the sticker fails the oil leaks out and makes a mess...this has only happened on two of the several dozen I have tested/ used in builds.
I think anyone concerned with how much a fan costs should be buying Yate Loons...if price is no option then San Ace 1011 are a fine choice.
Unfortunately the distributor for the San Ace linked by Vapor turned out to be very odd and refused me service after I questioned his shipping rates. So much for customer service. However you can still find these fans at subzeropc.com and a few other vendors. Expensive but I cannot se anyone complaining about their build or performance.
