Since your'e on the NB topic.. and I know it's off thread, but..
How many would like MCW30 special 4-point mount brackets made for the EVGA i680?
would it keep the price the same?? If anything gabe, i think a better mounting system for the SPP would be more prefered. Many have to custom design something, or use zipties. :nono:
But if it would keep the cost of the block the same to keep it competitive then DD's, im sure it would be a good option.
However, SPP!! mounting should be your primary task. :P More people buy these for that then the NB.
They are Euro style, with a indentation for the O-Ring to sit in, excuse the shoddy photography - company only gives us Ixus400 due to the fact we only take 640 res photos to upload every day, so nothing better needed. If I wasn't building a dual loop cube case - I would splash out on a SLR.
http://www.mekerz.tsohost.co.uk/Lian...eGTX%20007.jpg
http://www.mekerz.tsohost.co.uk/Lian...eGTX%20008.jpg
RE Teflon: Yeah, I know G1/4 the o-ring gives the seal but I suppose teflon tape has carried on from before G1/4 was popular. I wasn't into watercooling or probably PC's back then but when reading up before my first loop - teflon was the thing to do. So yeah probably un needed but as you say, no harm.
RE: eVGA 680i - Think it would be in your best interest to. Think out of all the 680i boards this will grow very popular due to eVGA being the only board to go for a revision to clock quads higher. I don't own a 680i board so no skin off my back. Even the DFI board doesn't do as well compared with a quad but maybe Oskar just hasn't hit the right nail yet.
ok..corrison may not be an issue but what about the long term bowing on the mobo...what effect will have
I am beginning to want ot upgrade my Storm....I never thought I would say this but the the GTX looks like a viable option
I hope in a few months to get a Lian Li V2100 and PA120.3
BTW..I am a big fan of swiftech(MCW60/Storm rev2,mcp655, MX159-cu)
I just hate the MCW60 mounting...I got right before the mounting setup changed last yr...I had no idea there was a change coming
Gabe really enjoyed this comment. I have been a supporter of your plating process from the get go. Even to where the "trusty mod" here gave me an infraction for blasting the ignorant, who are ignorant and know nothing but hearsay about this process. Not one of them has provided proof of failure of you plating process.
But alas, the average consumer isn't too smart or simply doesn't want to do a little research these days. Spoon fed is the way it is...
Ply
You can't blame users for questioning such things in my opinion. These blocks cost money, as does the tubing, rad etc and corrosion will happen in them all from one block. People have seen the crap thats left behind when it happens.
So it's kind of safer than sorry.
Thats not to say gabe can't be trusted, and I've never said he couldn't be in this thread - I think it takes a lot to sway someones perception of something once they have seen or experienced something bad about it.
Yet I take his word on the plating and the dye not affecting my coolant enough to warrant me worrying.
cant really answer your question on tihs neal. My board wasnt kept at the bow bend for a very long time. I did note it did sqew my NB mounting, which threw my system temps off the sky.
Ummm, 3 days of bowing and my CPu block showed almost no warpage. I did a flat test on it, and its still flat after i swaped over the oversized O-ring. Make sure you definitely use a good backplate, and get longer screws to help you mount the block. The stock screws wont work, there just too short.
Also, the MCW30 on the SB, is very tricky at best. I had to use old screws from my Maze4 GPU blocks to mount it securly. Bolting from the bottom is very tricky at best, because you cant get it perfect on the top go. The thing moves when you try to slide the bolt on the back, or the screw on top. Im sure if you fix this issue, your MCW30 sales will improve... i dont think you have a issue with it now, seeing how most places are SOLD out. :D
http://i125.photobucket.com/albums/p...a/IMG_0592.jpg
This is what i mean... wish i could get a cleaner top pick, but its pratically sitting on my video card. :T
And yeah. the SPP gets hotter then the MCP. Which is why a good mounting system is required. Even with this much flow, i still have a hard time keeping it under 40 at load.
What size mounting screws should I get? I'm planning on mounting with a back plate. :)
take your stock mounting screws. And goto a hardware store, unless gabe can tell you the exact size and catigory they are.
Then just get ones 3/4 of an inch to 1 inch longer. I always liked long mounting screws, thats just me, 3/4 an inch to make the black top lugs fit with little to no gap from your nuts.
1 inch for extra clearance so you can just slide the block and screws and everything without screwing the mount.
http://i125.photobucket.com/albums/p...a/IMG_0570.jpg
1.25inches longer screws were used in these pics.
If you have a DD block, i suggest you pick up some brass nuts.
Brass on brass = sexy to me :D
With all the new waterblocks coming out it is a watercooling junkie's dream! :D
Yea, I could see a brass Edelbrock, now that would be class. :cool:
Ur best bet would be to bug alex to make one... i think gabe announced his possition strongly on the brass top:
To requote:
The fact that a few of you are putting pressure on us to make a Delrin top (forget brass) for this block is one thing. And maybe we will in the future.. after all if it can sell a few hundred more water-blocks, why would I be against it? But the objective reality is simple: there is absolutely nothing wrong with the current process that we use to plate the GTX, period.
hey mcoffey, you do know the MCW-6500T uses alu on its top right?? i think it was mentioned a few posts back.
Your going back to your original delema now. :D
The problem with SPP is simple: 2 mounting points, and crowded area. Primary issue is rocking of the w/b due to lateral pressure exerted by the tubes. But reflecting on the problem gave me a solution I should have seen along time ago. So now I have to go work on it. Something's cooking!
Thanks !
Hmm, the GTX is testing far better than the GT. Confusering to say the least. I asked myself, "Self!", how is this possible? Swiftech says 1c at best. I am finding significantly more than 1c. Anyhow, is it JUST the diagonal waterflow? Lower deck height? Hmmm? Well, I have another theory which will be confirmed or denied tomorrow.
http://www.anonforums.com/builds/tes...on/apogee1.jpg
http://www.anonforums.com/builds/tes...on/apogee2.jpg
[QUOTE=nikhsub1;2119269]Hmm, the GTX is testing far better than the GT. Confusering to say the least. I asked myself, "Self!", how is this possible? Swiftech says 1c at best. I am finding significantly more than 1c. Anyhow, is it JUST the diagonal waterflow? Lower deck height? Hmmm? Well, I have another theory which will be confirmed or denied tomorrow.
QUOTE]
isnt that the top the the GT??? ahahaha..
I think you'll notice better temps with the GTX top. But then again, i think i scared teh pants out of you with my top pictures.
In that case, you are not testing the proper product and your results are not reflective of the actual product. At least state that disclaimer. One wouldn't think that the spacing of the barbs matter?
