Good point there max! forgot to mention this! although mine had only a drop or two of Chinese H2O in them !! use a lighter to heat the pipe and it will drip out.. press the end with pliers and ok! you can also solder the ends to be 100% sureQuote:
Oh, and when you cut those pipes be sure to get all the liquid out of them. I didn't get it all out of mine and it started to drip when the pwn heated up. Had to wad up a paper towel up in there until it was done dripping!
Yeap! as a mater of fact i do this on all boards! to ensure proper cpu-wblock or sink contact. some after market solutions provide metal support bars for under the pcb such as the thermal take H mount.Quote:
Maybe under the cpu socket area as well to help hold the board flat.
if you see the first pic in my post,Quote:
Not being an EE, could someone please post a pic with the various chips, etc. around the CPU socket area indicating name and cooling issues?
http://img109.imagevenue.com/loc154/..._122_154lo.JPG
you'll find the long "pulse chip" that is a 5-Phase Power Inductor, and 5 tiny chips part of a 5-Phase, Synchronous Buck Voltage Regulator Chip set by Volterra. The third chip lower in the middle is the rest of Volterra's chip set. Together they form the 5-Phase PWM (Pulse-Width-Modulation) Power drive for the CPU.
Data sheet: http://rapidshare.com/files/15321380...06_31.pdf.html
@ REVENANT: Sorry to hear this m8! Can you record that sound and up an mp3 of it? It would really help solving this one!
