D9GKX, no wonder they OC so sweet :clap:Quote:
Where did you get it? Link please.Quote:
Got it thru email. Not too sure what the changes are though.. seems to work similarly to 0401 as far as ram overclocking is concerned.. 4 slots.. 4 different results..Quote:
Originally Posted by PanteraGSTK
i'll email it to you if ya want.
Na, thanks though. I have my ram in the yellow slots and I'm able to get to 625mhz. 600mhz with 5-4-4-12 timings. I can even do 430mhz with 3-3-3-8 timing. However, I can't get 1T to work. I have heard of putting them in the black slots allows for 1T timing. What is your advice? Thanks in advance.Quote:
First, try resetting the cmos, unplug your computer, pop out the circular battery on the motherboard and put it back in after a few seconds. This should reset the bios. Let it load with auto settings. Double check your video card is seated well and sitting in the primary video card slot, not the secondary. If this doesn't work, I'd take your mobo out of the case to test it, see if it can boot up outside your case to make sure it's not shorting out on anything. Then I'd try moving your ram to the black slots if they're not already.Quote:
Originally Posted by introstand
1t works on both yellow and black slots for me. But the black slots seem to get the rams more stable (for me).Quote:
You might want to start at a lower speed to test for 1T too. eg maybe start with ddr2-667 4-4-4 1T
Bryan
I'll take a shot at that 0502 bios if you don't mind
Will you let us know if there are differences?Quote:
Originally Posted by John44
Yes, if he sends it to me. I will also have someone host it on his site
Edit: I have it. I will get back to you soon. Thanks Bryan
There is a downgrade in the ROM. I'm not going to flash it
well mine died last night for no freakin reason.
turned it on and nothing. powered on but no video, no post, no error beeps, nothing.
hard drive light stayed on solid and the cdrom light was blinking.
reset cmos, yanked the battery (which if your not careful you WILL break the battery retention clip.
still nothing.
welcome to ANOTHER Asus RMA.......
god i can't wait until that abit mATX board comes out.
Greetings gyes! The second day I understand with this mobo a payment. The first results not so. I can be loaded on frequency 1694 at the maximal v on northern bridge, but at further increase FSB the payment refuses to start... I have noticed that on it there is huge quantity FSB Holes, and because of it frequently there are problems with разгном. As I cannot include the set 2*512 Mb D9GCT in a mode 1:1. At exhibiting Sync Mode the payment changes multipliers 4:3, 15:14 and so on, depending on dispersal FSB... With pleasure I shall listen to your offers, and I will be grateful to your help... Thanks
Here are my results. Just look at that vdroop on load! I need the vdroop mod badly :(
Gonna have to get vdroop and temps under control before I run Orthos 24hours
http://img407.imageshack.us/img407/5802/screenyc9.jpg
Ok, this is what Ive managed to crank out of this mobo max stable benchable FSB. To be honest Im sick of this mobo, with all the boot-up flaws and everything and Im replacing it with a AW9D-Max.
http://bandwidth.se/imgs/16/42/4b828850le)_800_900.jpg
download memory ratios :cool: . Didn't know that was possible...Quote:
Originally Posted by nosleep
Has anybody else experienced random restarts?
nope. never had a problem like that when i had the board.Quote:
Been running it at 500x7 for 2 weeks, no random resets yet. I'm getting concerned about all the board dieing though.
not onceQuote:
If its orthos stable then you should raise the NB volts and/or cool it better
No issues here :)Quote:
Yes, that is one of the reasons Im replacing itQuote:
I'm having some nasty problems with this board, it overclocks nicely, but it seems to have some cold boot problem.
I have my 6400 running at 2.93 and it's very stable all day long, some days, when i turn the computer on it's completely unstable, sometimes it doesn't even boot the OS.
Usually, after a reboot or two, or power off and on, it's stable again.
Happens more than once a week, with all bioses.
Anyone had this problem?
Yes, the other reason im replacing itQuote:
Originally Posted by Eversor
That's the result of an instable overclock. Either pump up the volts or drop the FSB. My E4300 can boot at up to ~3.7ghz, but running Orthos at that speed results in an instant reboot.Quote:
I'm beginning to think it is due to vdroop. Or NB cooling. However, I had the stock cooler on my S3 with the same fan blowing on it and never had this problem. It seems to happen when the cpu is under load. I know my voltage setting is high enough because it is higher than my S3 needed to do 3.5ghz. However, it doesn't matter what speed or voltage I set it too, it'll run great, orthos stable, many other benches. Just happens randomly. I'm looking into a hr-01 sli chipset cooler that may help. I just wanted to know if anybody else had this problem. I'm still on the fence as far as a vdroop mod goes.
