I have mine sitting here un-installed, so you're in luck. Roughly 33mm by 33mm and the fins are about 25mm high.Quote:
BEat me to it :) Yes I get the same measurements.
I am now all set up first boot was fine and I have now installed Vista Ultimate RC1. No NVIDIA drivers for Vista yet (boooo). I may have to load Xp for now.
I am running at everything stock but I next want to OC 10% and start to get my experience and knowledge up to some of you.
Would someone suggest the initial settings I should change to get a modest OC, about 10 to 15%. I did set my memory to 1067.
With everything stock I am getting no buzzing, in fact the entire rig is quiet.
Where should I start with this OC adventure?:banana:
today arrived my quad :banana:
http://www.muenster.de/~e30pics/Bild...-1/Prime-1.jpg
Have SPi 1M and 32M with that? Thanks.Quote:
Originally Posted by Chri$ch
He is primeing at that clocks, it is stupit to ask for spi :DQuote:
Originally Posted by Speederlander
Chri$ch
Max fsb please:)
max FSB at this time is 470Mhz, CPU need to much VCore and goes over 80°C :(
3.70Ghz (463FSB) @ 1.47v is max Primestable
No tweaks, def. subtimings (6-42-10-10-10-10)
http://www.muenster.de/~e30pics/Bild...perPi-1M-1.jpg
http://www.muenster.de/~e30pics/Bild...erPi-32M-1.jpg
I'm messing around with RC2, with an 8800gtx. Try these drivers at guru3d (no sli though.Quote:
Originally Posted by Baer
http://downloads.guru3d.com/download.php?det=1554
ok, i test a little bit with open window :stick:
Bios settings: VCore 1.60v / vFSB 1.35v / vNB 1.60v / VDimm 2.275v / SB 1.60
max FSB 1M stable
http://www.muenster.de/~e30pics/Bild...perPi-1M-2.jpg
max FSB 32M stable
http://www.muenster.de/~e30pics/Bild...erPi-32M-2.jpg
Thanks, that worked. With the Commando I am not running SLI anyway. Most of my use of thei rig will be graphics generation and large reports for clients with gaming important but secondary.Quote:
Originally Posted by alejo
Anyway, this driver lets me continue to run Vista. Domo Arigato!
Is there any consensus on the cause of the buzzing noise issue that some have reported? It is making me a little leary of getting one.
Mine is quiet but then I have not started to OC yet.
I want to remove the copper rubbish so I can WC the NB & CPU. What would be adequate cooling of the Digital PWM's next to the CPU socket?
A row of Swiftech Copper heatsinks?
I'll have a 120mm fan right next them also.
[QUOTE]i see command rate 2t in your resultsQuote:
i cannot find command rate in the bios and it does not show up in cpuz for me?
can you tell me where you set this on commando
thanks baz
[QUOTE=bazx]i cant set the command rate, but CPU-Z 1.38.2 show it as 2T.Quote:
thanks baz
Deam 480 Mhz is nice, I waiting commando, so x3220,cell 1000MHz CL4 and home made water coolinig is ready.Quote:
Do you try to use old PCI card and increase PCI in bios like 120-130, FSB will go litle bit more:toast:
Does this board support chipset strapping change? If not, on what fsb does the strap change from 1066 to 1333.
Many thanks.
James.
400MHzQuote:
Originally Posted by jsbond007
Does not show bios 0702:confused:
Originally Posted by Supershanks
You are right.Quote:
Originally Posted by palese
You have to look for it another way by searching through the motherboard product listings...I discovered this the other day when it was first posted.
Well, I have it installed now and thankfully no buzzing at stock (e6600), nor at 8x400 whether idle or at load. This is with a seasonic 650 and evga 8800gtx.
think it's the asus site:slapass:Quote:
Yea a m8 told me after i've got it. i put it up here if u want it. Commando - Asus 0702.rar it's the EZ bios version.
luck:)
Alejo - lucky.
My Commando with 8800GTX and SeaSonic 650W buzzed. Returned it, got a P5B-Deluxe instead. A little sad about the Commando being gone, but the P5B-Deluxe is one hell of a board. A new BIOS came out yesterday too, I'm loving it.
That's not good to hear the Commando are buzzing with seasonics PSU's .
Anyone have a Corsair PSU hooked up to a Commando ? Since it's built by Seasonic I'm wondering if the buzzing has to do with the PSU manufacturer's internals(capacitors).
IMHO:Maybe the buzzing issue could be related to the low -5V line on the Seasonic built units.
I will be using my old Zippy PSU on the Commando board just received today.
Let us know if it buzzes, and by the way, no -5V line on modern PSUs ;)
Asus Commando + Tagan U25 700W, the buzz is present. I'm quite sure the PSU has nothing to do with this and the Vcore PWM's inductors are at fault; and it's not because of inductor saturation as it's doing it at any load level. Another possibility is insufficient capacitance on the +12V at the PWM input, will check it out tomorrow.
