Originally Posted by MrDeeds
439 x 9 (1066) @ 32 M so far
Originally Posted by Vice
I popped the spring clips off, then heated it with a heat gun on low, when it got good and warm, gave it a twist, came right off....
I was just curious, not trying to compete with a LN2 setup with my air cooled rig using PC 6400 ram :p: I don't bother with LN2 and my chip tops out @ 3.92GHz with only 1.6v available and air cooling. I need 1.65v for 4.0GHz flat which is the highest I've been on air. I was curious what someone could do with this board with better cooling and an E6600 on its default multi. Again, I am limited.Quote:
Originally Posted by Jaan
Highspeed seems kinda pointless practically if it doesn't net you any more performance. For example, my rig is the same speed @ 3.6GHz DDR2 800 3-3-3-4 as it is 3.6GHz DDR2 1000 4-4-4-4.
On the BX2, I can boot into windows with my ram to 544 @ 4:5 4-4-4-4 for 3922MHz so far and I don't have enough voltage to go any further with this particular chip. This same ram is good for DDR2 1100 4-4-4-8 on 965 with a 7x multi. (Tried a P5B Deluxe)
I may buy an E6300 to try in this board for the heck of doing so.
I posted a few days ago and asked if 4 sticks of 1 gig ram would work in this board. Thanks to everyone who responded.
Well, I got another 2 gig set of the Corsair Dominator DDR2-1111 stuff. All four of them work like a champ!!!!
Thanks again.
Shawn
Hi, this is a very nice thread!
I'm thinking of switching from the Asus P5W DH Deluxe to the Intel D975XBX2.
Is anyone running crossfire on this board and overclocking? I had some weird issues on my P5W, which got fixed after changing the stock NB heatsink. I suppose each PCIe slot will run at x8 when in crossfire? Can anyone confirm this?
Secondly, has anyone tested this RAM on the board?
GEIL PC2-6400 800MHz DDR2 Ultra Dual Channel Kit
Another thing I'm confused about is the CPU multiplier. Is it or is it not possible to lower the multiplier? I have an E6600, does that mean that I will only be able to choose x9 or more as multiplier? I've gotten used to using it at x8 on the P5W...
Last thing I'm wondering about is the IDCC. If I've understood correctly, I can use this to overclock in windows and then go into the bios to apply the settings, so I don't have to mess with the bios config jumper?
If I can just get an answer to one or two of these questions, I'll be very happy :D
you cant adjust multies in the bios :(
IDCC is no go for me. the splash screen just stays there and it vompletely freezeswhile loading :S
Ouuuuch... locked multi is not good... I'm not convinced about getting this board after all now :shrug:Quote:
Originally Posted by heikis
it's unlocked with kentsfield
with a future bios, it will unlock ;)
it's already there, only need to be activated (processor multi override)
is this a confirmed future feature..ie unlockrd lower multiplier??Quote:
Originally Posted by Supertim0r
Just wondering does Intel have most of the Bugs fixed on this 975 Board? You would think since Bad Axe 1 was around for so long that stuff would get ironed out.....and this Bad Axe 2 should be even more refined.
I'm pretty much trying to avoid any "first release" boards for my next build-up (most likely with a E4300 so I can stay on 1066 strap).
Why would you want a 8x multi over a 9x? Besides the strap issue I though all C2D worked better on their default multi?Quote:
Originally Posted by Pluppo
man I hope your right!! This would be REALLY awesome as well as fixing the HD led always on. If INTEL could fix those 2 things this board would be perfect. I love the stability and ease of overclocking once I figured it all out. Overall I love this board though.:)
can anybody give me the CPU and MEMORY settings when running 450FSB. i cant post at 450FSB :S 400 is fine and i havent tried between 400 and 450.
i have a feeling that the cpu extra voltage is not working
On the Bad Axe 2 how difficult is it to run dual 8x SLI? I assume I would need one of those SLI bridges right? How about getting drivers (where can I find?). How "buggy" are those SLI drivers....obviously they have no official support which worries me.
Anyone on the BIOS dated 20/12/2006? Is it any good? I'll flash it later after I've done last min Christmas shopping. :D
I don't notice a difference from 2330 and 2339
Thast would be great if that happened. I was like the issue with Everest Ultimate fixed on freezing when running the program as I paid for the program and would like to run it.Quote:
Originally Posted by malachi1313
The latest version of Everest works for me on this board. Have you tried the latest beta?
http://www.lavalys.com/beta/everestu...pij3xzweqc.zip
The link doesn't work. Which build is it?Quote:
Originally Posted by shawn1998
I have the 0837 beta build and while it works fine on my non oc'd boards, it locks up the oc'd box immediately and I have to cold boot to get it back.
Added feature to always display the latest event's date and timeQuote:
Originally Posted by zipdrive
of event log.
Fixed a problem where the system would boot to the wrong boot
device in AHCI or RAID mode.
Fixed a problem where the setup option for Floppy did not display
correctly.
Fixed the potential issue where all fans are on 100% when CPU is
changed.
Fixed the display alignment of the output values on the BIOS setup
hardware monitoring page.
Fixed the display of negative value on BIOS setup Hardware
Monitoring Page with some CPUs.
Added work-around for IDE-R 6 hour open session issue in a host
software package.
Fixed system continues to boot to next bootable device when no
IDER media present during AMT IDER & SOL session.
Fixed issue where POST errors may be displayed during Maintenance
Mode boot.
Fixed issue where system hangs after AC Loss if the Reference
Frequency is overridden.
Hide "Clear TPM" option in Maintenance setup page if TPM is not
enabled or not supported.
Fixed issue where Intel® Audio Studio does not launch with 3GB
Memory and certain PCI-E video card.
Removed USB 2.0 Enable/Disable question from setup.
Fixed AMT system only able to provision when USB device is
present.
Fixed issue where TPM Physical Presence was not cleared and locked
intermittently at the end of POST.
Added fix to eliminate fan speed surge after reset.
Fixed issue where Vista would hang during boot on systems with
Atmel TPM if the TPM was enabled in BIOS SETUP.
New PXE Base code : Intel(R) Boot Agent GE v1.2.42
Exactly the samething happens to me. There is a 840 beta build out too.Quote:
Originally Posted by gtj
http://www.softpedia.com/get/System/...-Edition.shtml
Are you at stock speeds?Quote:
There are no hacked drivers for the 8800GTX SLI but there are ones for the 7900 series . Just google (hacked SLI drivers) that is how I found them a while back, also there is a thread on this forum some where as well.Quote:
Originally Posted by Phosphate
And yes use bridge.
Yep, right now I am at stock speeds.Quote:
Originally Posted by badboy
Here is a link to the Everest forums. Look at the 4th post down, it has a link to beta build 840. I think someone else already posted it, but just thought this would be a good link to send. Maybe we could start a thread there and make them aware of the BX2 issues with Everest.
http://www.lavalys.com/forum/index.php?showtopic=1999
Shawn
Hi,
First of all thanks to all the members on this thead for great work. I've been patiently following this thread for last one month and have already ordered BX2.
Can someone write a decent writeup/review/guide on BX2 as the only available review compares with Gigabyte 965P-DQ6. This would further help people looking for a stable board to hit 400-420 range on E6600/Xeon3060.
Just a thought!
