look here:
http://www.xtremesystems.org/forums/...d.php?t=124363
qk4723Deluxe, how does that time compare to other boards like the P5B Deluxe and the P5W Deluxe...
Hi Guys,
Had any off you luck with the new evga p23 beta bios? I can't test it right now :(
Im still waiting on my new WC parts :slobber: post order needs a bit :slapass:
It seems on the evga forum that it fixes a lot of problems :clap: but im more interested in the OC improvements :cool:
DDR 1000 4-3-3-4 2t
1M :toast:
http://img182.imageshack.us/img182/8...g2jpg32tf5.jpg
what vdimm was that at ? memset screenie ? :)
DDR2 1000 4-3-4-4 2T
1M
http://img158.imageshack.us/img158/9387/1m4344zp0.jpg
Is there a way to use MS SM Bus drivers or should I be use Nvidia one's :confused:
qk4723Deluxe -
is 400 Mhz FSB (1600) 24 / 7 stable on that RIG?
Are you utilizing SLI?
I'm sure that having an SLI video card setup has to take away SOME amount of overclocking headroom. Just not sure HOW much.
I'm looking to run a 400MHz FSB with an SLI setup. Still debating on a board.
Originally Posted by Khaotic
Having no problems running sli with my evga 680i on mysystem OC to 3.83 24/7. Click compare link in sig for specs.
does anyone know where the voltage measure points are for ram and cpu volts ???????????
________
Weed vaporizers
VR-Zone has some.Quote:
Originally Posted by billdavis
Viper
Originally Posted by ViperJohn
yeah just found them
http://www.vr-zone.com/?i=4215&s=18
________
Alaska medical marijuana
hmm tested the vmem and it shows 1.95~ the bios says 2.5
and i have 4 gigs running @900mhz
so what gives
________
Glass Weed Pipe
can someone confirm the vmem measure point for me, Please
________
MAZDASPEED6
The Vmem metering point indicated at VR-Zone is correct.Quote:
Viper
Yea you are right.This is not correct.If I remember right,this is the right spot to measure vmem(I dont have the EVGA board anymore).Quote:
The leg you are indicating as correct is the mosfets Gate Drive.Quote:
Originally Posted by Phil The Greek
Viper
PTG the 1 u say to use gives me 2.21v
viperjohn the 1 u say to use gives me 2.01v
bios is still 2.5v
ive been running my d9 ram @850+ with 2.4vmem bios which is 1.91 at the measure piont
with a pencil mod the vr-zone measure point shows 2.39vmem but when booting it is up to 2.7vmem
with no pencil mod on boot up the vr-zone measure point shows 2.01 but when booting 2.4vmem with 2.5 vmem in bios
so what im trying to figure out is what is the right measure point if the vr-zone one is correct the high vmem during boot could be what is causing the ram issues on this mobo
________
TOP PORTABLE VAPORIZER
When you say "Bios Shows" are you refering to what you have set in bios as that can almost
meaningless sometimes if there are errors in the target VID pin tables in the bios. On board
sensors can also be grossly inaccurate. That is why you should always meter with a known
accurate DVM!
On my eVAG680i the actual memory voltage ran .048v HIGHER with the P21 bios and runs
.025v higher than bios setting with the P23. CPU Vcore is consistantly .040v lower than
bios setting. Every MB will be different and things can change with a bios flash if the new
bios has different VID pin tables than the old bios. That is one of many reason why people
loose or gain OC on a bios change. If there was a change/correction in the target VID pin
tables in the new bios then the voltages you think you are running have changed and your
OC react accordingly.
The test point indicated at VR-Zone traces to the Vdimm final filter caps and onto the VDD
input contacts on the memory sticks so it is correct.
Also make sure your DVM is reading accurately. Cheap VDM's that read to only two decimal
places (if it only reads to one decimal place then use it as a paper weight and nothing more)
can be even more inaccurate than on board sensors!!! You can check DVM rarely easily with
a BRAND NEW, UNUSED triple A Alkaline battery. It should between 1.605 and 1.610 volts
if your DVM is reading accurately.
Viper
My DVM is right on!
so then i guess it is just a bad mobo. that sucks!
where do i find the measure point for my vcore
new overclock
http://i107.photobucket.com/albums/m316/wcd26/ok-1.jpg
________
William clay ford, sr.
Probably not "bad" but definately different.Quote:
I know where the Vcore metering point it is on the back of the MB but that won't do you any
with it installed in a case. Not sure there is even one on the front side of the MB...at least
that you could hit with a CPU cooler installed.
Viper
Stability at 450 where it has been reported a hole exists...
If noticed that some boards have holes where others don't. One guy from OcUK was reporting holes between 405-408 where is board refused to boot. Mine works fine at these FSB.Quote:
Originally Posted by sdumper
