Nemesis I missed it before, thats a nice overclock on the 6600 :cool:
i have this board coming in on Friday so i need to prepare. Can someone give me a quick rundown on the best bios to start with? Any little tricks in the bios i need to know before i start cranking away at my E6600? Im using the DFI Infinity board for the time being but am pretty disappointed in not being able to reach 400+ FSB. Im crossing my fingers that my first Abit board wont disappoint.
As asked earlier, has anyone put some AS5 on the northbridge? Replacing the stock goop on my DFI with AS5 netted a 22C drop in temps so i suggest someone give it a try.
start with this bios. It's the 1.2 bios, the link is direct to abit ftp so it may be a bit slow. Set your timings manually under chipset settings. Under the guru section turn off all the cpu options like speed step etc. Your mch voltage will need to be set higher than with the P5W DH for anything above 350 FSB. Personally you probably should set bios to stock or moderate overclock and use gURU in windows to test overclocking. Thats what I like best about the board, I can play around with differnt overclocks without going into the bios and making changes each time. Good luck:)Quote:
Originally Posted by Budwise
hi !
well my AW9D MAX is arrived !! french abit lovers can order them at e-soph, the single way to have these boards for the moment in france
i just want my X6800 between 3.8 or 4.0 ghz....maybe i dream ithink...won't over 3.6 stable with p5bdlx..
anybody want good rams: buy gskill 6400 GA , my kit work at 1138 and i think maybe more with more volt and cooling, but very expensive..
Looks like a solid board allright.
Anybody knows where to get one in Canada?
Tankguys is in the states, but ships to Canada. They are located near Ann Arbor I think.Quote:
Originally Posted by neptunes
yeah you will need to change it with AS5 on northbridge... abit use thermal tape... that is not as good as AS5 conducting heat... keep the NB cool :toast:Quote:
AW9D-MAX @ 1,75MVmch / Kentsfield @ stock core, silent aircooling (coolscraper,120mm, 800rpm)
http://home.arcor.de/alonso_rudolfo/Kentsfield.JPG
Bios first shows funny things but then switches back to 4 CPUs ;)
http://home.arcor.de/alonso_rudolfo/9cpus.JPG
No multipliers above x10 in the bios for Kentsfield?
thats the situation here, yes...
abit didn't publish new bios to slove the question yet?:stick:Quote:
Originally Posted by Alonso
x6800 max 11x
KFD max 10x?:(
switched to P5WDH (Bios1305) right now - 20x available
imho still whola a lot to fix... ;)
alo
i have installed the board yesterday and there is a problem that i cant solve.
if i enable "raid" by the four satas ICRH7, save bios and the reboot if whe go again to bios and try to enter in Uguru menu the systems freezes completly,
the other problem is that if i dont go to bios after the reboot and simply try to configure the raid it gives me error and dont let enter the ICHR7 raid bios by pressing ther normal control+I
anyone have the same problema?
the solution was installing windows in single disk.
thanks
Dumb question,
My psu has two lines; one that says cpu1 and one that says cpu2 that are both 4pin, would it be proper to plug them into the 8 pin connector up top?
http://img169.imageshack.us/img169/2226/connabitsq8.jpg
is that the max FSB for Kentsfield you got from this board? :cool:Quote:
Tictac !!
Come on...a new bios for us !!!:D :D
^yeah.....:)
...Can you do anything with this one TicTac?
:D
Originally Posted by G H Z
Nah, the ati connector is different.
install the latest bios, that wil fix that issueQuote:
Originally Posted by jpcastro
I just ordered this board along with some Gskill HZ and an E6600.
if the board turns out to be a dud i'll cry... the reviews reported none of these issues... worried I won't hit 400mhz 1:1 now.
it work work out OK Richdog - probably .....
This board does not support SLI :rolleyes:Quote:
Originally Posted by Revv23
officially - although it does ship with an SLI bridge for use with hacked drivers. ;)Quote:
The board supports CF, there is one RED interlink sent with the board. Now unless this has the exact same pin configuration of an SLI bridge I think it's safe to say it's a CF interlink only.
It's advertised as: http://www.overclockers.co.uk/acatal..._Abit_176.htmlQuote:
Supports ATI CrossFire™,Supports Nvidia dual Graphics.
