f5 no difference for me, still capped @ 436 regardless of fsb/mch vbumps
I am a big trouble and I really need help.
I installed windows 3 times by now. So eveytime time I try this is over a fresh istall.
I cannot install the audio drivers. I install first the intell drivers that are said to be installed first and I have a sucess message upon intalation. I either reboot or not rebbot (tryed both)
Then I try to install the audio drivers. I used both from site and from CD. and everytime I get a message I have to install those genric drivers that I installed before and aborts the audion instalation.
I dont know what else I can do!
I'd sell the mb and pick up another one
Originally Posted by Aldy402
Maybe is your memory the bottleneck ?Quote:
I am at 3:2 with 3-4-4-12 400mhz with the Gskill DDR800 HZ 2gb, that's not right is it?
Originally Posted by The_Hardstylez
I am using the 2GB kit of this same RAM and it has been pretty damn good. I am stable @ 430FSB 1:1, and haven't really spend that much time tweaking to find the weak link. I got my kit for $177 (after rebate). Price has gone up a little.
Yeah, nice ram for a good price ;)Quote:
Originally Posted by gr8golf
My sticks are 440Mhz Mhz stable @ cas5.
Im using this set, booted without any problems, runs fine 900 2.2VDIMM 4-4-4-12, ~970 5-5-5-12Quote:
Guys, After a CMOS clear runs my X700pro @ 1X Pci-e :mad:
http://img171.imageshack.us/img171/6941/pciap6.jpg
How do i set it back @ 16X ?
Pci-e freq is 100Mhz. Default settings don't work.
Joe, you mind posting your bio's config.. I have that exact same setup.. except for my chip is still in the mail lol. Thanks in advance.Quote:
Originally Posted by Pjoeloe
turn it off for some time, then unplug power and do cmos reset, then boot, should helpQuote:
a friend of mine turned pc for 15min, done a cmos reset (no power cord, etc) and now is back @ 16x
So is there a way of setting higher vdimm? I can't get above 2.1V to work (OCZ Fatso D9 air cooled)
2.2V works fine for me with F4. I didn't verify it with a DMM though.
Hmz, I have take the X700 out of the pci-e slot and boot without videocard. It says now 16x :)Quote:
Originally Posted by CrazyJohn
norse:
That'd be affirmative. Tho I had the previous sticks in there @ 2.0...I was hoping it was close enough. :(
crspyjohn:
Ultra PSU for $5 is really worth -$$$ because it's going to blow up. :D I sold a few of those working at a ma/pa shop and they were known to do bad things...
I've got some Corsair 6400CL4's in now. They boot at default and actually ran a little superpi too, lol!
highly doubt it , they're micron d9 chips and they're teamgroups with no heatspreaders, I even tried pushing 2.4 in them to make sure it isnt them. Even relaxed my timings to 5-5-5-15 , no diceee. D9s should be doing 1000+ without a hiccup at that many volts and relaxed timings.Quote:
although I have no other mobo to test my theory, hmm...
Well today i went and got me a PCI VGA cheap card to try out with no luck at all !!!! same overclock than b4 with my 7600gtko, play with timming memory increase voltage decrease increase voltage on cpu up till 1.6 (crazy) no matter what i do it wont pass 368FSB stable , to be honest i dont know what could be eaither the CPU or DS3 , play with divide it and notin set it up at 2.00 play with timming notin, set it at 2.50 and notin , i spent so much time with this board (no funny) ME NO LIKE DS3 , ,but im also think thats probably my cpu limit not sure , those guys out there hitting 400 and up FSB are so lucky
Ive try everything on this FAQ and the most i can hit is 368FSB
E6600
DS3- F4 bios . best that worked for me
Corsair 2gig 6400C4
enermax 550w
Any suggestion guys?
I booted right up with no problems using this
http://www.legitreviews.com/article/332/
running 4-4-4-9 @ 960MHz right now
it's hard to find though, I got mine through Ewiz but it is no longer available there
on the frequequncy thing my best stable is in the 360's also, I booted at a little over 400 but it was not stable for 15 min with Orthos even with 1.55 volts, plus the temps even with the ware cooling were shooting up toward 60C. So I am running 360 x 9 @ 1.39
I soloved my slow-reading-DVD drive by upgrading my bios from f3 to f4. I personally believe that it is caused by the DMA. Somehow I cant enable DMA under f3. once I upgraded the bios to f4, the DMA was automaticlly enabled.
however, my computer still keeps crashing and blue screening with the f4. can someone here help me?
my pc:
core 2 e6300
glaxey 7900gt 256/256
apcer ddr2 1g 667*2
2 sagate hard disks linked as raid mode
Gigabyte needs to set the initial boot up to be at 2.0v or 2.1v for ram. Can't they set it to be different than the actual speed, like F1 BIOS was booting at 66Mhz FSB, then going to fullspeed? Just so us tweakers with fast ram that needs 2.0+v can freakin boot up properly.
I'm upgrading to some new sticks of ram later this week. I have other sticks which boot at default that I'm going to sell later, so I'm going to be scared to upgrade BIOS's later. B/c I might get stuck with a NO BOOT.
Gigabyte needs to set the initial boot up to be at 2.0v or 2.1v for ram. Can't they set it to be different than the actual speed, like F1 BIOS was booting at 66Mhz FSB, then going to fullspeed? Just so us tweakers with fast ram that needs 2.0+v can freakin boot up properly then set our voltages, etc.
this has allready been fixed in the latest biossQuote:
Originally Posted by chrisf6969
Is there any alternative program for managing Azelia?
Crazyjohn any suggesion bro?Quote:
Originally Posted by Ajfina
How I can flash the bios from USB? I don't have floppy, so I cant take any bootable files from there. And also why my IDE/PATA-drivers are shown as SCSI, and I can't see my IDE-HD in windows (in bios and Device Manager I can see it)?
