That isnt real carbon fiber is it? Looks like vinyl to me.
it's vinyl no question about it. LD has also mention that.
Superb work my friend :clap: carbon look is very nice :up:
Well done my friend. :up:
Best regards,
DagoDuck
Hey littledevil, a "simple" question. Would it be possible to chrome the compressor? Would look so damn nice under some blue lightning in a silver V2100
case.
painted compressor means no warranty, but for sure, it's no problem to paint it with "chrome".
but i wouldn't recommend v2100, to small airflow true the front since you have the door in front. v2000 is a better choise.
regards
Tim
i don't think so. since the method to make the crome can cause issues for the sealing between electrical socket and shell.
if you want to make it "chrome" either paint it or polish it and clearcoat. to be honest, I would keep it black.
Course, I'm simply brainstorming a bit :)
You could chrome it if you make sure to cover the electrical plug with wax. And make sure you don't get acid in the compressor.
Nice Work :up:
Nice work, clean and sleek.
:D
Thx LD....
Next stop for that nacked SS is Norway.
Cant wait to test it, i know it will perform good.
You are a true master in youre profession, be proud of it :clap:
--cheers--
Very well done. What kind of model is this compressor? :)
Looks like that one is going to be built to your same high standard !
I'm just curious. those condensers is rated for 700watts, and what rotarys do you use?
what loadtemps do you expect?
well I have to say, I'm very happy with the size of those rotary cases (i got two my self without the gauge and controller holes).. but it's enough space to build autocascade in there, and I will build one for my self (already in progress). might try that instead?
regards
Tim
It looks like a LG NJ282P R-407C or LG NJ236P R-407C compressor.
teyber:
it also depends on refrigerant ;)
New backplate issulation for SS and POTS.
http://ld-phasechange.com/images/issulation/1.jpg
Regards
Hey LD,
i still need the GPU Mounting ;)
@Xtasy: PM me your details please.
Here are some pictures of finished unit.
@250W load.
http://ld-phasechange.com/images/bre..._rotary/10.jpg
http://ld-phasechange.com/images/bre..._rotary/12.jpg
http://ld-phasechange.com/images/bre..._rotary/13.jpg
http://ld-phasechange.com/images/bre..._rotary/14.jpg
http://ld-phasechange.com/images/bre..._rotary/15.jpg
http://ld-phasechange.com/images/bre..._rotary/16.jpg
Regards
the controller looks a bit crooked :shrug:
