Uhhh if the IHS is on, you won't be able to supply that many volts without kicking temps way past 50c, which at those speeds means instantaneous error.
Ok
I gues it is not worth it
So iwont do it.
And about the IHS
I screwed few 144 taking the ihs off, cause cracked the core,
what can you do to prevent that??
by the waterblock
Got my CPU from Absolute_0 today and threw it in and cranked it up...
http://i5.photobucket.com/albums/y19...pteron1463.jpg
ihs on or off? what kind of load temps you get with 1.62v ??
just wondering how long it can survive :nono:Quote:
Originally Posted by dz`
My IHS-less opty 148 from thebeast, very pleased with it considering my meagre clocking skills.
http://i3.photobucket.com/albums/y57...s/PCmark04.jpg
Dont you think most people in this thread have something similar already? :p:
no JUST WOUNDERING,
sOME PEOPLE ARE INTERESTED IN BUYING MORE
Didnt think selling outside the FS section was allowed, but nevermind.
Final summary before selling it :toast:
these tests are realised under chiller, with liquid at -24°C CPU around 14°C
i've tested to find cold bug, apparently it was at 5°C for 420Mhz HTT, then it's possible to improve this result...
WR Max screen 3657.8Mhz :
Valid 3657.8Mhz
Screen 3657.8Mhz
It can bench at 3480Mhz (liquid at -22°C) but i think was limited by the memory to have problem with high frequancy..
CPUMark 3480Mhz
Boot at 3.54Ghz, then probably possible to bench over 3500Mhz with this cooling
Boot Ã:banana: 3537Mhz
stabilized at 3350Mhz for -22 to liquid
OCCT Strable 3348Mhz
aircooled : ambiant temp around 14°C
Prime Stable 2700Mhz for 5H40 1.2v slow speed cooling
Prime Stable 2808Mhz for 7H52 1.248v medium speed cooling
Prime stable 2906Mhz for 5H49 1.280v full speed cooling
420 CPUMark at 3215Mhz 1.472v
SuperPI at 3194Mhz 1.472v
aircooled : ambiant temp around 6°C
Max screen 3460Mhz 1.6v
Validation 3460Mhz
Boot at 3339Mhz 1.6v
OCCT Stable 3058Mhz 1.376v
436 CPUMark 3310Mhz
Nah I was wondering becuase im getting load temps over 50 @ 1.53v with my xp-120 and 93cfm fan (which in my eyes is like top 5 in aircooling setups). Thinking I might have to pop the lid to at least redo the paste between IHS and the core.Quote:
Originally Posted by kenofstephen
That 146 ugp has loads in the high 40s with 1.62v and aircooling. It's the coolest running Opteron i've seen.
HI guys
I'm just wondering Opty 144, 146 babies overclocked at FX 55, 57 speed, they really perform like their overpriced brothers? Is there any bench or comparison test?(video encode, game test)
I really need to know before I move on to Opty???PLZ
Performance between FX and Opties at teh same speed is identical.
Have you ever compared your Opty's with FX benchmark?
my personal comparison doesn't change the fact i just stated. You can doubt me, but anybody here will back it up. Only thing the FXs got is unlocked multis, possibly better memory controllers.
Sure the fx is a hot one but i'd rather go buy a opteron. But besides this i wanna know the lowest temp anyone reached with a removed IHS + watercooling on a opteron 146. I've been as low as 14 celsius but the normal idle temperature is 19-21.
http://img116.imageshack.us/my.php?i...aked1464ry.jpg
I'm new here so i haven't been able to follow up other thread's.
Hi All
Well i thought my CABNE0545 did ok for 2980Mhz on 1.525v but the CACJE 0601 I picked up is far better with 2900MHz at the mo on 1.30v
May put it under the prommie when done but even on air cooling(Folding at home fully stable at 35deg C)Have full stability on P95,3d2001-2006 but havent tried OCCT yet.
Smiffy
He is correct:p: He would know sice I bought this Opteron from him:p:Quote:
Here is another screen to add...
http://i5.photobucket.com/albums/y19...46/SiSoft3.jpg
http://i5.photobucket.com/albums/y19...CMark-6188.jpg
killer_pav :
you have PM.
no-one is interested ... :pQuote:
Originally Posted by killer_pav
i'm interested in a 146, reaching 3ghz @ MAX 1.5vCore ;) (aircooled)
3ghz @ 1.6vcore is almost usual nowadays ;)
But mine runs cool:hump:Quote:
Originally Posted by brechtvm
