i used in quite past tygon tubes, i loved the clearnes but, i had to remove them because in less than a month the choke... don't know why... so i'm looking for some clear tubes as tygon, but the do not have to choke.....
whoa d4l super clean niiiice
Well I hope the pictures of my case are any good.. all those slick cases and mods here... i'll do better on my next mod :)
http://i655.photobucket.com/albums/u...d/IMAG0262.jpg
http://i655.photobucket.com/albums/u...d/IMAG0261.jpg
http://i655.photobucket.com/albums/u...d/IMAG0260.jpg
http://i655.photobucket.com/albums/u...d/IMAG0259.jpg
http://i655.photobucket.com/albums/u...d/IMAG0254.jpg
New mobo...
PC specs:
- Intel Core i7 2600K Processor
- Asus MIVE-Z motherboard
- Corsair Dominator GT 2000MHz 8-9-8 2X2GB DDR3 DRAM
- 2X MSI nVidia GTX580 SLI Graphic Cards (GC)
- 2X Intel SSD X25-M 160GB Gen2 Solid State Drive in raid0 (SSD)
- WD Caviar Black 1TB SATA3 hard disk drive (HDD)
- Corsair AX1200W Power Supply Unit (PSU)
- LiteON 24x DVD-RW Writer
- LittleDevil PC-V8 Inverted Casing + LianLi Alu case feet black
- Dell Ultrasharp 3008WFP LCD Monitor
- Logitech Z5500 Speaker
- Asus Xonar D2X Sound Card
Cooling gears:
EK Supreme HF Plexi-Nickel - CPU block
EK MIVE Plexi-Nickel WB - Mobo block
EK RAM Block for Corsair DomGT Plexi+Nickel
2x EK FC580 GTX+ - Plexi+Acetal - GC blocks
1X Feser TFC-480 Quad Radiator (for GPU loop)
2X XSPC RX480 Quad Radiators (for CPU loop)
2X Swiftech MCP655 Vario Pump with EK D5 Top POM
2X EK Multioption X2 250 Advanced Reservoir
Bitspower & Feser Compression Fittings mainly silver shinning 1/2" ID 3/4" OD
Primochill Clear Tubing 1/2" ID 3/4" OD
Primochill Blood Red Non Conductive coolant
16X Scythe GT 1850rpm fans
2X Aerocool Shark Devil Red 140mm fans + DEMCiflex fan filter
http://i458.photobucket.com/albums/q...D/DSC_0056.jpghttp://i458.photobucket.com/albums/q...D/DSC_0066.jpghttp://i458.photobucket.com/albums/q...D/DSC_0067.jpghttp://i458.photobucket.com/albums/q...D/DSC_0068.jpg
wow . nice.
do you really need this many rads to cool that rig? ;d (rhetorical question)
Big machine - big LC :)
PS.
the same question you can ask Elder ;)
shame its black and red /barf
Attachment 118457
Attachment 118458
Attachment 118459
Attachment 118460
More pictures, including an outside shoot with much better lighting http://profile.imageshack.us/user/dwr083/
Specs:
Thermaltake Armor A30
890GXM-G65
Phenom II X4 965 OC'd to 3.84
6GB DDR3
2x 500GB HD's in Raid 0
HD 6950 (second one on its way)
My first LC build. It's pretty difficult to fit it all in that tiny case. The only way to mount the rad was directly on top.
Attachment 118527
Attachment 118528
Attachment 118529
Attachment 118530
Well, since you showed yours I guess I'll show you mine. ha. I apologize for the crappy photo skills.
Asus Maximus IV Gene-Z
i5 2500k @ 4.8Ghz
16GB of DDR3 @ 2133MHz
6 X Crucial C300 128GB Raid 0
2 x GTX580's
http://i162.photobucket.com/albums/t...y/DSCN3470.jpg
http://i162.photobucket.com/albums/t...y/DSCN3356.jpg
http://i162.photobucket.com/albums/t...y/DSCN3359.jpg
Now the ugly side....this is under my desk. I was laying on my back looking up. Just to give you a bit of perspective for the camera angle.
http://i162.photobucket.com/albums/t...y/DSCN3471.jpg
Dual loops in a 350D is pretty impressive. What kind of ~200mm radiator is that at the bottom?
It's a 200mm by Phobya
By the way it's not so difficult thanks to the Koolance RP-452X2 tank
Thanks ;) i tried to make the clearest config i was able to do and what i most love of my new changes is that the connections to the radiator of 240 aren't visible.
The tubes are masterkleer one's, i discovered that this tubes are really translucid and they are really flexible.
What is that back plate on the GPU?
Is it fixed to the pcb or just laying on top of it?
It's a custom backplate ;) done by one of my friend , fixed to the pcb.
It could be lighted on
http://ludovic.postal.free.fr/HARDWARE/650D/Night-1.JPG
