Originally Posted by
Diablero
Finaly i could fully stabilize my OC. Q9550@3.77ghz - 444x8,5 @1,32vTT, @1,32v vcore and , full load and bios. (no vdrop). (0,695GTL on both)(Sken=normal, performance mode (optimized get me unstable).
BUT, it was hard becase i think my motherboard is overvolting the NB.
First i was trying to stabilize with more volts and later willing to try to reduce the voltage, because of that i was trying with 1,24v and up on NB (, and always instable.., everyone is using this or more on vnb, and i tought that i would have no problem with that..., but..
Finaly 444fsb with 1,2v only (0,64GTL), but 1,22v get me unstable... maybe the vnb is overvolting by a x amount over the bios setting, i will try to measure the vnb with a multimeter later, anyone knows the spot can give me a hint?
Another thing, 9800GX2 is pci-e sensitive? because with 101mhz on pci-e i get freezes on games, and with 105mhz i get no post. i have to set 100mhz only.
56c Full on highest core, and 51 on lowest, with a 30c ambient temp.
while OCCTing and priming, its an ok temp for a custom handmade watercooler, right? i will change my WBlock soon.
