Originally Posted by
eSp!s0
Ok, after removing Asus pipe carefully and with no problems I mounted the two HR-09, the HR-05 and a Enzotech cooler for the Southbridge and put the board into my system again and started.
It made a short noise like sth. was burning and it smelled like also. One of the chipparts on the board between sata ports and casefrontpanel connection at the buttom of the board was burned. This little chip is far away from the removed pipe and mouted coolers.
Do you sink, that I had a bad day, or did I made a terrible mistake when removing pipe and mounting new coolers, because the burned chip is that far away from anything I touched.
Just ordere a new one now only without SE. I´m not very lucky with my pc atm :(
