aholland, it might be possible that your cpu just can't oc beyond 3ghz :)
What bios are you running? I've been having similar problems since I flashed to 1901. For me, leaving the system with the PSU switched off over night usally fixes it. It's extremely annoying though!
Does anyone know where I can find the 170X bios? I can't see it on Asus' website.
Edit: Woops, sorry. I need to get some glasses, it seems :P
2004
maybe been asked before and i have searched and cant find it but how would i get a 1:1 divider for a overclock ? spec are as sig and i only wish to oc a little bit ive tried 300x8 and ram gets a 3:4 i think it was and then i tried 333x8 and got a different divider so how would i get a 1:1 with a 333x8 oc ? so take my 2.13 to a 2.6 thanks
1:1 divider will be DRAM Frequency = 2x FSB
So 667mhz if at 333fsb.
yea that was the other divider i got b4 but i thought 1:1 was better thats why i was aiming for it
:shrug: new to oc'n but yea thanks for the help will run it at the 4:5 :)
hi, what is the best bios version to overclock an e6600 with?
Interesting....
http://www.rage3d.com/board/showthre...eadid=33889730
I wonder if Asus will impliment it...
ChrisC
Have you read any of the recent post on this thread? The latest BIOS is 2004 but depending on what you have and what setting u use its whatever works best for u with your setup as there does not appear to be a lot of difference from 1602-2004. Check the post for peoples different opinions and take your pick. Me - I like 1707 as its never caused me any issues and I get a good stable o.c.
Will /probably be in the next BIOS update. Should be soon, G-0 stepping is on its way :)
NONE!!!...............there is no BEST BIOS!!!..............read this thread from start to finish :rolleyes:Quote:
Hi All,
I just installed the Win XP on my new P5W DH on a SATA HD connected to SATA 3 (Black). A really annoying thing is that everytime it boots up, a message showing:
"NO IDE Master HDD Detected" and I have to press F1 to continue.
Do anyone know how to fix this? I can boot up fine but it's just very nagging. I searched everywhere and couldn't find a solution. Probably plugging the drive to SATA 1(Red) will fix it but my HR-05 totally blocked it:(
Thanks!
RTM, put the drive on the port indicated as boot in the manual. (Sata 1 = boot disk) page 2-34.
EDIT: you did answer your own question.
Hello !
I'm Spanish, sorry by my bad english.
Nowadays, I have a ASUS P5W DH Deluxe with 2Gb GSKILL PK's, but the problem is that this motheboard don't detect very well the timmings of this memory and I "only" can do 410*8 = 3280 Mhz.
I would like to do 430 or 435*8 and I think this Motheboard can do this because if I put the memory with a divider I hit this frequency without any problems.
Do you know what memories can do it without problems ?
Thank you very much
On the side note, what the hell should be done to let drives be recognized as "2nd/3rd/4th" IDE MASTER? Any jumper setting will do? It seems that anything connected to the SATA 3/4 will be recognized as SLAVE (don't know about SATA 1, EZbackup and JMicron one)
Hi,
Can anyone send me a voltage.ini file from MBM and some screens from MBM voltage settings? My MBM shows sick +5V voltage and V-core. My mail: xxwolf@poczta.onet.pl
i have the same problem. i have my raid 0 raptors connected to the ez raid ports. my other 2 devices are in the black ports. whether i change them around or not about 80% of the time my system boots i get this message. if i hit f1 to continue it goes nowhere cause this only happens when it doesn't properly detect 4th ide master. 4 ide master is of course the raid 0 drive. i just hit reset until it sees it and then it loads windows no sweat. i basically can't oc right now cause it's too much of a pain in the ass when 80% of my boot ups error and require an additional reboot anyway.
anybody else havin problems with the official 2004 bios ? i cant seem to overclock no more says something about winload in the system32 (vista business) folder has a miss match checksum but if i revert back to bios/defaults it works no problems i even tryed going back to the beta 2004 but still the same any suggestions ?
