From every post I have seen, 06 chips appear to be going another 100mhz further than the initial rush on the 144-148's of last fall.
Futuremark doesn't say anything about stability, i was able to run 3dmark01 at 3.1 Ghz on the stock heatsink with one of my 146s, although it could barely prime at 3 Ghz cuz of heat.Quote:
Originally Posted by radcruiser
thats the reason I said bench stabile. still testing, its game and prime stable @ 2950 mhz @ 1.52v with air cooling.
Ok, got myself an Opteron 146 CACJE and wasnt hoping to achieve more than 2.7-2.8 outa this chip, from what i've seen posted here.
First attempt:
146 CACJE @ 2700.88 MHz / Air Cooled / Prime Stable
Mutliplier = x10
HTT = 270
Voltage @ 1.5 BIOS (Burning it in, might be possible to lower it)
CPU Temp = 31-33c IDLE
FSB = 270
RAM = 180
Update: Dropped CPU Voltage to 1.475 and upped HTT to 290
Currently running:
146 CACJE @ 2920.88 MHz / Air Cooled / Prime Stable
Mutliplier = x10
HTT = 290
Voltage @ 1.475 BIOS (Lowered from 1.5v)
CPU Temp = 33-34c IDLE / 40c Full Load
FSB = 292
RAM = 194
Seems like i have room to hit the magic 3ghz mark and possibly more :woot: Seems like 2006 is a good year ;)
P.S. New to the overclocking scene too, not bad for a first try eh? :)
http://i21.photobucket.com/albums/b2...146oc29ghz.jpg
Well i thought i had killed my 146 when i removed the IHS turns out it's alive and kicking. I mounted my watercooling on the naked core and OMFG is it flying, right now i'm priming at 3.15 Ghz with 1.50v, and the room is warm...
Just did this
http://img.photobucket.com/albums/v7...E/e8d1e878.jpg
Definitely one of the best 146s i've seen. If you've got a better 146 on normal watercooling i want to see it!
Is that a typo or is AMD labeling chips with april date? :DQuote:
@overcrash: Now you need a hole in the window so you can close it on the cool winter days ;)
No 0604 is 4th week of 06 not 4th month.Quote:
Originally Posted by mursaat
He holds an umbrella above it then :p: :toast:Quote:
Originally Posted by Big.Wayne
0604 means Year 2006 and Week 4.
seems my CPU can handle 3.1 Ghz with 1.45v no problems :)
http://img.photobucket.com/albums/v7...E/e53715e5.jpg
boxed cooling ?:eek:Quote:
amazing:slobber:
plz post your stepping :)
Boxed cooling? Holy hell no, boxed cooling this thing loaded at like 60c with these volts. This is IHS removed and watercooling!
What stepping? What other than CABQE 0547GPMW! :)
lol:clap:Quote:
nice:banana:
i have a CABQE 0547 GPAW
another guy, with the same cpu, was able to hit 2.8ghz @ 1.45vCore, with arctic freezer pro...
mine can hit till 3.2ghz, @ 1.6vCore right now (no decent cooling)
when my neo2-bios is updated (waiting for a winnie cpu, or nc, or clawhammer), i will post my results :)
problem : it's nforce3ultra (no nforce4)... and i read, nforce3 limits oc's :( (i even thought you wrote the article :D)
lol, i prefer plug the chiller :DQuote:
i've tested today, -24°C to liquide :
http://wowgame.free.fr/Divers/chille...%20-24%b0C.jpg
http://wowgame.free.fr/Divers/chille...or%20froid.jpg
WR opty 144 improved : CPU around 14°C
http://valid.x86-secret.com/show_oc.php?id=75334
http://wowgame.free.fr/Opteron%20144...l/cpu-3657.jpg
just testing max boot at 3.54Ghz :slobber: :
http://wowgame.free.fr/Opteron%20144...03.45Ghz-2.jpg
http://wowgame.free.fr/Opteron%20144...Mark%20457.jpg
cant test superPI, my 2k3 was dead :slapass:
and stability test :D
http://wowgame.free.fr/Opteron%20144...201.504v-2.jpg
just for testing before sold it :banana:
Hmm yeah, I don't know what I was thinking. My 165 is 0551 :slap: :slap: :slap: Lack of coffe this morning if you ask me :DQuote:
Originally Posted by Rufus7
I found what you said ;)
source : http://www.gamespot.com/pages/unions...&union_id=3092Quote:
Cooling is another big factor, but it's pretty obvious. Motherboard is much more important than most people realize. Motherboards like the MSI K8N Neo1 and Neo2 hold back overclocks. I should know, i've owned both. If you are REALLY and truly interested in overclocking, i seriously advise you to consider the DFI NF4 Ultra-D and nothing else.
--> Is it that bad ? :(
It just means DFIs clock best ;)
Please get rid of that link :slapass: :slapass: :slapass:Quote:
Originally Posted by brechtvm
You can push it to the limit, when you're using a DFI motherboard, thats a fact:)Quote:
Would my MSI Neo2 hold me back for about 100mhz(or more) ?
(in comparison to an DFI motherboard, with nforce4 chipset)
or is the difference in clock-speed rather small ? (at same vcore etc...)
Other mobos hit HTT limits, my Neo2 Platinum didn't work past 275 HTT, i thought it was a bad CPU, nope just a crappy motherboard. Also this is kinda OT next time you have a question like that use PMs...
@Absolute 0, Glad to see you got your water going, those chips were ready for it.
@overcrash86, awesome chip. Cool 'liquid' setup. I use similar with vc only not as extreme.
Just did this testing Di tubes...:D
http://img136.imageshack.us/img136/4913/32mb9tw.jpg
and I can't resist, I had some left over last night and used it for this,
http://img527.imageshack.us/img527/3...ime33005oi.jpg
Jesus coop, 32M at 3.57, beautiful. That DICE really hits the spot.
agreed, there is a sweet spot in there, temp wise. I have to run Systool to monitor temps. Like that prime? lol
well, I got my old CABYE 0540 FPAW:Quote:
http://img506.imageshack.us/img506/9...e0164yb.th.jpg
http://img506.imageshack.us/img506/5...e0135ed.th.jpg
This is on air, IHS still on ;)
(this was before I even bothered with prime)
and a sick low volts:
http://img506.imageshack.us/img506/3...olts1kl.th.jpg
I have to sell this gem now, customs ripped me off big time on that 170'er...:(
..have to sell on Ebay though, can't let it go to cheaply..
3.1 on air is nice, but 32M doesn't speak as much as Prime, i can run a 32M over 50 Mhz past where prime fails. The main reason is that Prime loads me 2-3c higher than SP32M. Still a very nice chip though - especially for air and IHS still on!!
