I agree...MUCH better. External watercooling components can truly kill the aesthetics a build.
Aesthetics is a relative term, something which people here forget...
A personal opinion on what looks appealing is all anyone can physically share--the beauty is in the beholder :)
the mod is good but i don't like this antec case, but overall it's a very good job
Here's my mess:
http://img.photobucket.com/albums/v4...2/HPIM0600.jpg
Nice.
I have a p180b am currently putting together a WC system for it. I used your build as some early inspiration. I already have the tripple rad, filport, T and tubing. I'm just not sure about the pump. I want to put mine in the top HDD bay so I'm torn between the 655 and 355 which would be easier to fit.
Looks like the back end of the 655 would fit in the empty bay. Why didn't you mount it there?
Thanks for the comment, The pump would fit in there, but I had a limited supply of tubing and I also wanted the loop to be compact. I tried the empty bay and it would be a bit of a hassle to route tubing for the outlet of the pump as I didn't want to do more cutting than was necessary. It fits well though, doesn't touch anything inside and it's pretty secure.
My first H20 build.
Armor case
Corsair 620 PSU
Asus P5N32-E Plus 650i
E6600
Crucial Ballistix Tracer PC6400 4x1gb
8800GTS 320mb
H20 setup:
Swiftech MCP655-B 12V Industrial Water Cooling Pump
D-TEK Customs Fuzion CPU Water Block
D-TEK Customs Fuzion GFX GPU Water Block / Swiftech MC14 Bga Memory Heatsinks / Swiftech MOSFET sinks
Black Ice Xtreme II Rad (2x120mm) with 4 x120mm Logisys 63CFM fans in push/pull on a rheobus
Swiftech 7/16" tubing and Tygon 1/2" tubing
Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir
Temps (celcius) are:
CPU 26 idle and 40 load. Prime stable at 3.6ghz (with fans set to lowest speed on rheobus)
GPU 36 idle and 40 load - 660 core and 927 RAM
Ambiant 24
http://img.photobucket.com/albums/v6...bigdustbox.jpg
http://img.photobucket.com/albums/v6...Hobbit/1-1.jpg
http://img.photobucket.com/albums/v6.../Darklight.jpg
Not bad, but if you paint the interior of the case black, it would be looking much better:yepp:
Upgraded my baby with some GPU cooling. Sorry bout the blurry pics, taken with my 810i cellphone cam.
http://img503.imageshack.us/img503/9198/dsc00394ff7.jpg
http://img101.imageshack.us/img101/1446/dsc00404mr3.jpg
Even though I ordered the swiftech sinks like a week or so from petras, and they should have the new thermal tape, it still sucked! Didnt stick whatever I did, tried heating the sinks up, etc. So I went with the superglue-in-the-corners-method, worked like a charm. :)
http://img208.imageshack.us/img208/7474/dsc00427er3.jpg
hey haydeehobbit, what kind of hd coolor is that?
i heated up swiftech heatsinks with a blow dryer. Stuck on pressed firmly for 15 secs for each ram sinks and left for 2 days for the thermaltape to reach maximum bondage.So far been really firm and hasn't feel off
So, guys, FINALLY finished the project Water Inside! Here is some pictures :D
http://www.bandwidth.se/images/1739
http://www.bandwidth.se/images/1740
http://www.bandwidth.se/images/1741
http://www.bandwidth.se/images/1742
http://www.bandwidth.se/images/1743
http://www.bandwidth.se/images/1744
Motherboard: Asus Blitz Formula SE
Processor: Q6600 G0 @ 3,6ghz
Mem: 4* Ocz FlexXLC 9200 1gb (4gb)
Graphice: XFX 8800Ultra
Systemdrive: WD Raptor 36gb, 16mb cache
Storagedrive: Samsung Spinpoint 400gb
PSU: Corsair HX620
Watercooling: DDC-2 + Petras Top, Bix2 + Bix with titanffans, EK 8800 delrin fullcover, Apogee GTX, Swiftech MCres, tygon 3603 slang everywhere.
NysoO,
I followed the worklog of "water inside" and I think it's a pretty nice case you've made there! :D
keep up the good work!
@ NysoO: i love the 5th pic down. i love white clear light on nice clean clear tubing with water in it!
hIGGINS WHAT TEMPERATURES DO YOU HAVE ON THAT GTX
Kick @ss rigs guys!
that pump is huge is it a alphacool pump?
Looks like an Iwaki to me. The pressure in that tiny ID hose must be immense...
GoldenEye, is that a Asetek Waterchill kit?
