Originally Posted by
DrTeal
I've been playing around with my OC again recently, working on tweaking things with LLC off in the hopes of getting rid of the random 0x124 BSODs... Anyhow my question is this: What the heck is up with this board? I'll run LinX and everything will pass, but I can come back the next day and run it on the exact same settings and it will fail on the first or second pass, then the next day it passes again.... I'm not really sure whats going on here. I ran several passes of memtest with no errors so I don't think its related to that. I'm seeing the same issues at 3.2 GHz so I don't think its the CPU being pushed to the edges of its capability, and 400FSB should be no where near a wall - I mean, this board supposedly supports 1600FSB. RAM is 1:1 @ DDR2-800 4-4-4-12. CPU temps @ 3.6 [9x400] are 70C max in LinX, @3.2 [8x400] they are 55C so I don't think temps are causing the problems either (CPU and push/pull washermod TRUE both lapped... so I'm out pretty much out of ways to improve the cooling except gong to water... and if I could afford that, I could afford a new sandy bridge cpu/mobo/ram). Running BIOS 0902 still.
If it doesn't appear to be a CPU or RAM problem, it would have to be something mobo related, right? Any thoughts? I haven't had any crashes playing games since this latest round of tweaks, just LinX weirdness.
