It is tempermental, but it will get up there, clockwise. It was hard for me to control though with DI and not having any temp monitoring device. See the SD thread please.
I dont remember exactly the full temp , but it was arround 47-48°
146 0540 FPBW under watercooling
3.1ghz 1.48v
http://users.skynet.be/pt1t/146/Prim...0mhz_1,48v.PNG
3.2ghz 1.63v
http://users.skynet.be/pt1t/146/prime_3200mhz.PNG
What a chip! :DQuote:
Originally Posted by Pt1t
Here is my opteron... 0540FPBW 3504Mhz @ 1.72Vbios
http://www2.shrani.si/pics/img1293ivtp39_thumb.jpg
cab2e 0546 fpaw
290 x 10 @ 1.45
284 x 10 @ 1.4
primed stable
cab2e 0604 ?dtaw? (i'll check later)
301 x 10
1.392
super pi stable (priming)
298 x 10
1.392
super pi stable (prime later)
:toast:
Originally Posted by LitleDevil
Did you try max suicide cpuz screenshot ?
wow nice CPU you got thereQuote:
I'm testing this CAB2E 0546GPAW; not bad... 3288MHz@1.57V with CPU at 6°C. I've seen a 3309MHz screen and thought the validation was done but it wasn't...
http://valid.x86-secret.com/show_oc?id=73776
http://www.beforeoverclock.com/images/cpu-3288.jpg
Not bad... more to come :D The waterpump really suxx actually :slapass:
3001MHz@1.42V
http://www.beforeoverclock.com/image...6-VoltCore.jpg
http://www.beforeoverclock.com/image...6-CPUGraph.jpg
2902MHz@1.37V
http://www.beforeoverclock.com/image...7-VoltCore.jpg
http://www.beforeoverclock.com/image...7-CPUGraph.jpg
@ Before :
only one word : AMAZING :slobber: :eek:
Thx mate! :D I'll work for higher clocks... :p:
CABYE 0540APMW
Notice temp drops without IHS and 0.05V less @ 3Ghz :toast:
http://www.xtremesystems.org/forums/...1&d=1140650150
My little contribution:
opty 146 0546 GPAW @ 3042 vcore 1.58v
Aircooled SI 120
Temp < 42°C FULL:banana:
http://img51.imageshack.us/img51/6487/30421580zs.th.jpg
I've not resist to the temptation of passing over 3.3GHz; yesterday I was at 3288MHz@1.57V :D
CPU Max Screen @1.65V = 3356MHz chilled C2H5OH CPU@6°C | http://valid.x86-secret.com/show_oc?id=73996
http://www.beforeoverclock.com/image...AWCPUZ3356.jpg
Anyone has results of the CACJE 0601 GPAW on air? the only one to post something was AndreYang but I think he's on water right? 24c idle, 31c on spi32m load with 1.408v seems water to me :)
Check here
Some very results for this stepping... :D
Thanks! I always forget that magnificient database. Well, didn't know it was so up to date :)
Did you see this? --> - OPT 146 | CACJE 0601GPAW | 3150 mhz | 1.568V | Ad aria | Link (simoneco) :clap:
Yeah but no temps in the screenshot and only a CPUZ 1st page. I wonder which memory, divider, cooler he's using
"Ad aria "; it was air cooling... may be with opened windows :D
This rocks that AMD is actually getting BETTER cores out over time. Looks like almost all of these latest chips do 3ghz+ without the need for prometias and stuff.
just recieved a cab2e 0546 fpdw from the egg today. was wondering how this steping was? going to install it later tonight.
Looks nice,Quote:
now did anyone tell you about the *print-screen* button :)
Photo is beter for stability ^^Quote:
Originally Posted by Big.Wayne
http://img52.imageshack.us/img52/2457/klock6cp.th.jpg
Check that out, 3000MHz on 1.39v
It does 2960MHz on stock voltage. More to come, my mem stops me. So first of I will have to check out settings for my mems before I try more than this. Cooling is a Thermaltake Big Typhoon @ 1300 rpm. idle/load 29/38
