yes just make sure your RAM is stable.... i.e. memtest and multiple superpi runs :)
Will do. May just use a divider to run it at stock lol. If I go water cooling I will go for more. Thanks.Quote:
Originally Posted by dinos22
Jared
I had to redo mine one time. Doing the 1m Spi ratio thread. 2400mhz was the best ratio and I was using CGen at 343x7. I tried to reboot and start from 342x7 and corrupted it. Just make sure you have a clone or copy that you can just "paste" back in after you format. BEFORE you try for corruption.
**edit** I think using CGen is safe, just don't try to boot like that.
32M with 146 0540 FPBW under watercooling
http://users.skynet.be/pt1t/146/32M_3201mhz.PNG
Nicely done!!
hmm ive seemed to hitt a wall on my opteron 146 cab2e fpaw
what do u guys think is better to use the 9 multiplyer or the 10 because on the 10 which im currently priming at (10 x 274) for 3 hours and as soon as a go to 275 it can only prime for 2 minutes... any suggestions
i have a dfi lanparty ut ultra d and x800 gto2 and 1 gig generic compusmart ram i think this might be holding me back
3dmark 05 6548
148 at 3ghz and still tweaking.
http://img70.imageshack.us/img70/989...rime8ft.th.jpg
Nice nice! :clap:Quote:
Originally Posted by Pt1t
How high can reach on air? thx
Are you running memory on 1:1?Quote:
Originally Posted by Rott3n
Originally Posted by bobov
Dont know , i have only the radbox ... but prime stable @ 3ghz 1.39v in air ,screen @ 3.4ghz and 3ghz @ 1.38V in wc, screen @ 3.45ghz. Prime is also stable @ 3.2ghz and all 3D benchies :D HIS still on :rolleyes: . in Few weeks , i m going to waterchill it :p
I wish lol. 5.4 right now. I can't get these g.skills to run faster than rated.Quote:
I'm in similar situation here with a 148 opty and my G.Skill HZ. I popped the IHS off the opty and got it up to 3030 P95 stable with a divider, but my HZ sticks are hitting a wall at 270, so I'm capped at 11x270 1:1 until/unless I can tweak this config to get the HZ to catch up.
Nice, what idle/load temps were you seeing?
I found my gskill HZ kit didn't like 5/6 divider.Quote:
DFI LANPARTY UT nF4 SLI-DR Expert (12-7-05)
AMD OPTERON 175
Patriot Dual Channel XBL 2x512MB PDC1G3200+XBLK (tccd)
EVGA 7800GTX 256MB, PCI-E
Western Digital Raptors 2 * 75gigs
Western Digital Raptors WD740GD 74GB 10,000 RPM
LITE-ON LTR-24102B
PLEXTOR DVDR PX-708A
SONY DVD-ROM DDU1621
PC Power & Cooling 510 SLI-PFC ATX12V 510W Power Supply 90 - 264V UL/ ULC/ TUV/ CE-Retail
Genie BIOS Settings:
FSB Bus Frequency - 275
LDT/FSB Frequency Ratio - 3
CPU/FSB Frequency Ratio - 10
PCI eXpress Frequency - 100Mhz
CPU VID StartUp Value - STARTUP
CPU VID Control - 1.550v
CPU VID Special Control - Above VID * 102.4%
LDT Voltage Control - 1.40v
Chip Set Voltage Control - 1.68v
DRAM Voltage Control - 2.84
DRAM Configuration Settings:
DRAM Frequency Set - 166=RAM/FSB:5/6
Command Per Clock (CPC) - Enable
CAS Latency Control (Tcl) - 2.0
RAS# to CAS# delay (Trcd) - 03 Bus Clocks
Min RAS# active time (Tras) - 06 Bus Clocks
Row precharge time (Trp) - 03 Bus Clocks
Row Cycle time (Trc) - 10 Bus Clocks
Row refresh cyc time (Trfc) - 13 Bus Clocks
Row to Row delay (Trrd) - 02 Bus Clocks
Write recovery time (Twr) - 02 Bus Clocks
Write to Read delay (Twtr) - 02 Bus Clocks
Read to Write delay (Trwt) - 02 Bus Clocks
Refresh Period (Tref) - 3120 Cycles
Write CAS Latency (Twcl) - Auto
DRAM Bank Interleave - Enabled
DQS Skew Control - Auto
DQS Skew Value - 0
DRAM Drive Strength - Level 11
DRAM Data Drive Strength - Level 1(Reduce 50%)
Max Async Latency - Auto
DRAM Response Time - Fast
Read Preamble Time - Auto
IdleCycle Limit - 256 Cycles
Dynamic Counter - Disable
R/W Queue Bypass - 16 x
Bypass Max - 07 x
32 Byte Granularity - Disable(4 Bursts)
Prime95 + 3dMark2001SE + CPU-Z 1.32 + Everest 2.50 Ultimate Edition 2006:
http://joek71ny.tripod.com/images/finaltest.jpg
http://joek71ny.tripod.com/images/finaltest_1.jpg
http://joek71ny.tripod.com/images/finaltest_2.jpg
http://joek71ny.tripod.com/images/cpu-z.jpg
http://joek71ny.tripod.com/images/mem_settings.jpg
http://joek71ny.tripod.com/images/memslot.jpg
http://joek71ny.tripod.com/images/memslot1.jpg
http://joek71ny.tripod.com/images/setting1.jpg
http://joek71ny.tripod.com/images/prime95_14hours.jpg
3dMark2003:
http://joek71ny.tripod.com/images/3dmark.jpg
EVEREST 2006:
http://joek71ny.tripod.com/images/everest_latency.jpg
http://joek71ny.tripod.com/images/everest_read.jpg
http://joek71ny.tripod.com/images/everest_write.jpg
short description:
275*10 @ 2750Mhz, 5/6, 1.550v + 102%
2.0-3-6-3 @ 2.84v vdimm
I decided to play some more with my opt 146 until my dual core chip comes in.
3027@1.42volts PI calculations.
<a href="http://img137.imageshack.us/my.php?image=30279im.jpg" target="_blank"><img src="http://img137.imageshack.us/img137/9713/30279im.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
You can always use a divider.Quote:
Originally Posted by scottk
BTW, CACJE 0601 GPAW seems to be a very weak series. Mine can't get past 2880 even with 1.7v... It's going back to my reseller this afternoon, I can get my money back if I return it in less than 7 days :D
@Mursaat
Have bought CACJE 0601 GPAW 146 this weekend.
Works at 2950MHz with Air cooling with 1,5V (primestable). 3000Mhz works
but not primestable. Isn't that impressive compared to some PMWs but "good
enough" for me. ;)
BUGGI
Well I've tried even with memory 120 divider. What I forgot is to relax MAL and RP, will try later, but don't think the Opteron is not able to manage MAL8 at ~200Mhz... What memory do you use? can you post all your config? Thanks :)
@Mursaat
Using an MSI Neo 4-F with 2x512MB "old" Samsung DRAM.
Config as always:
HT Multi = 3
Core @ 1,5V (look at the picture)
NF4 = 1,55V (normal settings, don't do aggressive)
Bus = 295MHz
DRAM Clock = 133MHz -> runs then at 197MHz with 1T and CL3
Cooling is air (Artic Freezer 64 with FAN @ 5V -> look at the picture)
Thanks a lot BUGGI!
Anyway I've sent the chip to my reseller right now. I have the right to send it back in less than 7 days, I get the money back (in the shop, but it's my favourite shop :D)
Not even 2850 with 1.4-1.7v :( I will stay with my 165@2600 with 1.375v for a while
Is that a CACJE 0551 TPMW? I can't find any info on CACJE 0551 TPW8, so maybe that was a typo? Thanks! :)Quote:
Originally Posted by halo112358
//EDIT Sorry for the double post. I did second quoting from the page 184, an hour and 4 minutes later, and I thought there should've been posted again :D
Alright this is my 2nd best, the 0154 batch CPU on my stupid air cooling with frigging terrible temps.
http://img.photobucket.com/albums/v7...E/a6fad857.jpg
http://img.photobucket.com/albums/v7...E/5d554aa3.jpg
I don't think too many Opterons can prime at 3.1 with 1.56v and 48c load ;)
"I don't think too many Opterons can prime at 3.1 with 1.56v and 48c load"
You have a point there. Get your h2o going.
Yeah yeah the block is coming in soon.
Hey you know that CABYE i got from you - that thing is HOT! I put it on air and gave it 1.6 volts and started SP2004 - jumped to 60c instantly!
And on the phase change, well it just about overloads the single stage. It does what i say in the sig, but when i give it 1.63 volts, loads at +14c!
It's a good chip to be sure, but man it's hot, it needs a better single stage to run on and it would fly.
