How did you use an 11X multiplier on the Opteron 146???!!!
A bios flash??
A bios flash??
here is my full thread about 11x multiplier on Opteron 146 :toast: :fact:Quote:
Originally Posted by turbox997
http://www.xtremesystems.org/forums/...ad.php?t=88876
I have install my opteron 150
CACJE 0551 TPW8 ( lucky revision?)
http://img301.imageshack.us/img301/9385/280x115di.jpg
I have do stability test at 3100 and 3112mhz (283 x 11,1.45V).. OCCT pass, super PI too (27.248 PI 1M, no tweaks on DDR,2.5-4-4-8 1T can do certainly 2.5-3-3-7)..
My ask.. i will try go for 3.2ghz then, what is the max Vcore don't shoot on the Opty for stability? if it don't keep at 1.5V, 1.55V.. 1.6V is a lot for this type of opteron?.. i got it since some hour only don't want burn it first day..
Need say the Opteron have really impressive me.. really easy to set with OCZ4800, incredible like it go stable fine with stock voltage on start...
Originally Posted by dinos22
That is awesome!!! Friggin sweet!!! Haha, I wish I had that.
I'm running mine 24/7 with 1.58 Vcore on air, load temps are under 44C at all times. I think up to 1.60V is OK, if it took 1.625 to make it stable at 3.2ghz then I'd think that was OK too :DQuote:
Originally Posted by Lane-k
jeeze you run 1.58 volts and it only loads at 44c? I load at 46c with 1.45 volts. Lapped ACFreezer64 pro and lapped IHS.
Hello guys, could you give me an help to understand my cpu ?
I bought an Opteron 150 stepping CABGE 0532MPMW ... i was thinking that it is a very good step but i cant make run it more of 2805mhz stable after a superPI 32MB
i not expert but i tryied to give more voltage from the bios...i also tryied 250x12 with 1.550v + 104% :shrug: :help:
am i so unlucky to have bought a not good cpu? :(
i post an image about my config so you can see better the syterm configuration...:confused:
http://img102.imageshack.us/img102/8...1550v0i.th.jpg
Probably need a little more voltage than that. Try 1.5Quote:
Originally Posted by [ITA]SEREUPIN80
hello, i wrote wrong value... i wanted to say that i tryied 1.550v + 104% :(Quote:
Originally Posted by MaStA
Well on air I wouldn't go over 1.5-1.55. So that just might be your cpu's limit. Are you sure your ram is not limiting it? Might want to try a higher divider.Quote:
Jared
i dont think that are the ram because i tryied with them at 133mhz 2.5-3-3-8 do they were under 200mhz while i tryied... :(
i really hope that this isnt the cpu limit ...i was hoping to have bought a good cpu :(
Overclocks are never guarenteed though. :stick:Quote:
Try using the x10 multi, some CPU's prefer running x10 :)Quote:
really i don't know.. pehraps have you no luck.. but it's strange you can't go higher.. I can use any multiplicator for OC all work.. 308-310x10, 285x11,265x12..etc.. but yes.. sometimes some CPU like more one or another multi..
all work if i have Prime or OCCT instable ( 3 minute after the end of test).. i up the voltage a little bit no problem..Are you sure of your settings for your DDR?
Is your prob can come from the temp?
Very Very TrueQuote:
That's a good chip Absolute, every time you post a pic it's always good news, haha.
I'll have a screen shot soon, but the other day I decided to play around with my chip some more(I was running 2.81@1.37v primed for 9 hours)... well long story short, after I played I couldn't prime it without the volts changing on me.
SO, I'm running at 2.80@1.32v now.. undervolted it. Primed for 20min then I stopped it before I went to bed.
It is a 148 and the screens a bit old but still running it today.
http://img124.imageshack.us/img124/1...20045du.th.jpg
http://img124.imageshack.us/img124/8...144v5fk.th.jpg
@Absolute, get your h2o fixed?
is image shack down? it hasn't been working for me.
It just took me a long time to load ^.
So is it true your hard drives begin to corrupt if you run over 315 for a long period of time?
Thanks,
Jared
first time i hear about this myself....i'd say it's an isolated problem with a system that wasn't stable in first place......with drive corruption i'd say it was a memory issueQuote:
I have not experienced it. Chew is actually who told me this and I am pretty sure you two communicate, so maybe you can talk with him about it.Quote:
Jared
chew has a funny choice of motherboard and is a hard core ocer...........I would say that's the reason why he'd see the corruptions.....but it isn't that widely known...........i happened to be running most of my systems at those HTTs and above for the past year and i never had an issue like that nor heard of anyone other than you mention itQuote:
i have heard of plenty of guys mess up their hard drives with over eager OCs and pushing RAM too much but not high HTT levels :)
So with my setup I am fine to go over 315 you would say? :cool:Quote:
I've been thinking about going with watercooling, but figured if going over 315 would corrupt my hard drive it wouldn't be worth the money to me. I may still go with it then.
Jared
