I've been through three different sets of 2 x 2 GB so far:
OCZ ReaperX 1000MHz - Maxed at about 1066 MHz - 5-5-5-18 at 2.1v
G.Skill 1000MHz - Run at stock speeds, but when I tried to OC them, got Memtest86+ errors - seems they only like 333 FSB on this board (in my case anyway)
Mushkin Redline 1000MHz - 1056 MHz is the highest I could get. 5-5-5-12 TRD 7 at 400 FSB with a quad seem to be their sweet spot on the 266 strap at the stock speed of 1000MHz. Anything above 400 FSB and they require a higher TRD and the bandwidth actually can go down.
Of course I'm not the best overclocker around, but I do a lot of reading and research on stuff.
I am now going to try the Dominators 1066 MHz and also a 4x1 set of Mushkin 1066MHz XP2 sticks (which supposedly can do 5-5-4-12 1200MHz) and see how things go.
If you want, I can run some tests when I get everything in, as I will hopefully have all of this memory here in the next week or so.
