PC8500, Ballistix Tracer :rolleyes:
does this new bios still have the unable to downgrade problem just like 0903?
Hi, that's why nobody uses it, as I said before, it uses the external diode, no good for those die-hard overclockers..
Chris
so far :scope:
Hi, my initial impressions of the 0907 is good, running and a oc of 3.6ghz. I've put back in my 4 x 1gb Crucial Ballistix PC8500, run them at 1066, 5-5-5-15 @2.19 volts and managed to run prime for over two hours, where as before it wouldn't last ten mins. I know that's not absolute proof, but it's looking better.
Chris
I think these image will speak for itself.
http://img402.imageshack.us/img402/7088/0907by0.png
Completely stable
Warboy, what did it take to achieve that before? Voltages? Temps?
what are your settings in the asus bios. I hope 907 Does wonders too.
did anyone managed to water cool this board?, i have 1/2OD Tygon Tubing, i know the Fusion Block is 3/8 but iam just wondering about the leakage and deffrence between air and water cooled on it.... Pictures would be nice too
thank you
SNIPoR, take a look at this thread here http://www.xtremesystems.org/forums/...d.php?t=162085
Computer just rebooted and I got this message. opt temp3 overheat protection. . Could anyone explain this to me?
I am also getting randon crashes when I exit Enemy Territory game.
I ran memtest for 12 hours no errors. Thanks for any help.
quad 6600
maximus formula bios 802
g Skill MEM 2Gx2|GKS F2-8000CL5D-4GBPQ R
msi raedon 3870
coolmaster 750 power supply
cosmo 1000 case
So you have full confidence in the new 0907 warboy? Are your vDIMM spikes still there with this BIOS?
Warboy, you're using 2 Dimms right? What Bios settings are you running for 475MHz?
hey i posted in the other thread but thought i would post over here to see if anyone could help. Never overclocked and just want to dip my feet into overclocking slightly.
Is there any settings guide for say 3ghz? as i just want to push it up gradually.
Im currently on q6600 with 4gb (2x2gb stick) of ocz reaperx ram, any help would be really appreciated. Also im on a air only setup.
First impression (hopefully not the last one) of bios 0907: Bios does not recover from crahes as gracefully as 0903. Also, it would have none of my 8x480 on the 266 strap after crash. Back on 0903 (for the moment).
Boot from bios:) Thats more like it fellas:up:
on what cooler ?
What settings are we using to get high FSB on 0907? Please can people post voltages etc for these FSB's. I am now testing this bios and it would help alot.
