Looks good... I like those xigmatek's too. :D
DONT QUOTE IMAGES!!!
..looks cool that gtx!
Very nice :up:
Don't you get tired of cleaning your system when there's ton of dust :)?
I clean it once a year, and I don't keep the same system for more then 2 years. So, no.
Then what about noise?
Is that loud? and what's are the cpu's clocks? :P
It is very quiet... Those CPU fans are panaflo's 80-85CMF @ 32dB, and all the other fans are <25-28dB... I use it with doors closed, and I keep it inside a cabinet I have on my desk... You can hear it, yes, but it is very quiet...
http://img.photobucket.com/albums/v2...723/HAF002.jpg
My computer case never has been cleaner than that! :D
This is really 'Air Cooling';
http://i390.photobucket.com/albums/o...ans-241106.jpg
(source=www.techchee.com/2007/11/24/obsessed-with-cpu-cooling-pc-case-with-66-fans-and-wrapped-in-ice)
^ that looks crazy!
Talk about obsessed aha :)
Not sure, but I think it's Delta fan.Quote:
Originally Posted by mcaff
Nope.
Yeah.
It's a Sanyo Denki San Ace 1011. Amazing quality, moves a lot of air and thanks to their quality motors it's very quiet.
http://www.petrastechshop.com/12x38sadesan.html
Somehow "moves a lot of air" and "very quiet" dont fit very well in the same sentence. No matter what fan it is, a high rpm fan that blows lot of air is ALWAYS loud. No matter what fan it is. Ofc if you're accustomed to fans that sound like leafblowers you might think that a fan like that is quiet.
Everyones idea of noise is different.
Good gawd that's the most fans I've ever seen in a Stacker. Don't tell me you have 4x120mm in the side door panel too??? Do you really need all those fans?Quote:
Originally Posted by Simps;3557133[img
For a 38mm fan, it's quiet. Also, since I typed that post on my phone I couldn't go into detail.
The fan is quiet for a 38mm and undervolts properly. Compared to other fans I haven't experience any motor noise when they undervolt, my Ultra Kazes let off a whining sound though whenever I undervolt them (both of them). In no way was I referring to quiet as in... Noctua fan quiet, but for a 38mm fan they aren't as noisy.
I have three of them (as seen in the pic), all of them undervolt properly and I haven't experienced any clicking.
Also, how were you powering the fan?
I'd say the review is accurate for my card as well. VRM temps > 70C after load. I assume the difference is that the stock cooler places the fan directly over the VRM plate. I'm watching this thread to see what people come up with: http://www.xtremesystems.org/forums/...d.php?t=210897
I'm not terribly worried about it though, since the GPU is much cooler (delta of > 10C) and it creates less noise.
