the CPU at 4200mhz like it is on the screenshot froze my PC i had to restart and i put it on 4.0Mhz just for now and so far it hasnt frozen.
When u have it at 4.2 and 4.0 do your MHz for the memory change ? Try a higher uncore with minor adjustmnets on other volts as well .. Lol ocing is such a pita !!!
Yes my memory was at 1600mhz with 4.2 and now its at 1520mhz with 4.0
Anyone tried de new F13M Bios?
have you tried f13k?
I am currently using F13M bios. Currently not having issues.. I have not checked I think it is F12 (key) to choose boot source.
or im sure if you keep hitting escape you can do boot source as well..
Im currently using the F12 bios do you recommend me chaning to any of the newer bios that are out there?
I noticed that since i changed to the F12 bios my PC tankes longer to get into windows, maybe because i have 2x500 Raid 0.
Anyone?
If works ok, why do you have to change anything? :)
It just might be better, my PC now takes longer to get to the Windows loading screen since i put the F12 bios
I prefer F12 myself. I tried most F13 betas, the reordering of the bios after F12 looks like a mess and has to many unnecessary subcategories to navigate to get to each setting, F13betas are a nuisance for me.
@Godmyster
Than just return to older BIOS that was faster at loading the OS.
F9 is great BIOS too but I find F12 the best all around.
Ok if you guys say its best ill stick to it then :P
My setting at the momento are:
Advanced CPU Features:
CPU Clock Ratio ................................ [20]
Intel(R) Turbo Boost Tech ...................... [Enabled]
CPU Cores Enabled .............................. [all]
CPU Multi Threading .............................[Disable] - Enabled if you can boot and/or temps ok may need extra vcore
CPU Enhanced Halt (C1E) ........................ [Enabled]
C3/C6/C7 State Support ......................... [Enabled]
CPU Thermal Monitor ............................ [Enabled]
CPU EIST Function .............................. [Enabled]
Virtualization Technology ...................... [Disabled]
Bi-Directional PROCHOT ......................... [Enabled]
Uncore & QPI Features:
QPI Link Speed ..............................[x36]
Uncore Frequency ............................[x16]or x17, x18 (always 2x +1 or +2 of memory Multi)
Standard Clock Control:
Base Clock (BCLK) Control .......................... [190]
PCI Express Frequency (MHz) ........................ [100-102]
C.I.A.2........................................... .. [disabled]
Advanced Clock Control:
CPU Clock Drive ..............................[800mv]
PCI Express Clock Drive ................... [900mv]
CPU Clock Skew ............................. [0ps]
IOH Clock Skew ............................. [0ps]
Advanced DRAM Features:
Performance Enhance ...................... [Expert]
Extreme Memory Profile (X.M.P) ........... [disabled]
System Memory Multiplier (SPD) ........... [8]
DRAM Timing Selectable (SPD) ............. [quick]
Channel A + B + C
Channel A Timing Settings:
##Channel A Standard Timing Control##
CAS Latency Time ......................[9]
tRCD ..................................[8]
tRP ...................................[8]
tRAS ..................................[24]
CR.....................................[1]
B2B.....................................[auto]
Advanced Voltage Control:
CPU Intel Core i7 920 D0 Stepping
Load Line Calibration ................. [enabled]
CPU Vcore ..............................[1.3]
QPI/VTT Voltage 1.150v .................[1.34]
CPU PLL 1.800v .........................[1.6]
PCIE 1.500v ...........................[1.5]
QPI PLL 1.100v ........................[1.16]
IOH Core 1.100v .......................[1.100 - 1.200]
ICH I/O 1.500v ........................[1.5]
ICH Core 1.1v .........................[1.1]
DRAM
DRAM Voltage 1.500v .............. [1.64]
DRAM Termination 0.750v.......... [AUTO]
Ch-A Data VRef. 0.750v ...........[AUTO]
Ch-B Data VRef. 0.750v ...........[AUTO]
Ch-C Data VRef. 0.750v ...........[AUTO]
Ch-A Address VRef. 0.750v ........[AUTO]
Ch-B Address VRef. 0.750v ........[AUTO]
Ch-C Address VRef. 0.750v ........[AUTO]
I ran Linx 20 and its perfectly stable :)
Im running F9d Bios.. I find i can get the highest bclk on standard volts with this bios so I have kept it..
Out of all F13 betas the F13M is the one that give me back my OC (4200 with low voltage 1.24V) from the F9... :up:
Hello
Firs excuse my english.
I have buy a GA.X58A-UD5 rev.2 and I am not sure abotut the memory to choose.
I am looking for compatility and no problems
I have to choose between
F3-12800CL9T2-12GBNQ (2Gx6)
http://www.gskill.com/products.php?index=110
or
OCZ 3x2GB DDR3-1600
OCZ3G1600LV6GK Gold Ed.
LowVolt 8-8-8-24 1.65V
http://www.ocztechnology.com/product...triple_channel
OCZ 3x2GB DDR3-1866
OCZ3G1866LV6GK Gold Ed.
LowVolt 10-10-10-28 1.65V
http://www.ocztechnology.com/product...le_channel_kit
Can you help me? What is the best choice?
I have seen also
Runs well OCZ3P2000LV6GK on GA-X58A-UD5 rev.2?
The kit OCZ3P2000LV6GK is compatible with my matherboard (runs well on UD5 rev.2)?
And the kit OCZ3P1600C6LV6GK?
Thanks regard
Hello guys,
I'm here with a problem and would like to know if someone already had something similar or who has heard of this, my gigabyte board X58-UD5 apparently has 1 memory slot (White Slot) that is not working.
I use triple channel 3x1GB but the funniest thing is that in the My Computer properties says "3GB (2GB Being Used)" , and CPU-Z also detects the 3GB and in triple channel, however when I turn the PC says that detects only 2GB of memory, I tried switching bios (F9 to F12) but no resulte,
Can someone can tell me anything about this?
Because i didnt want to send this to RMA and not having a PC for a while appreciate all the answers.
Regards.
You want to solve the problem? No problem but you'll think it's freaky idea.
I'm telling you that it's working so... get the tooth brush and clean the socket pins. Yes you heard me!
And another thing, what cooler do you have?
I just resolved the problem strange but logical, 1 of my CPU socket pins wasnt exactly lined up once i got it straight and got the CPU in and my Cooler (H50) everything worked fine, its strange but i got it to work that way :) so if it happens to you guys now you know :)
That's nothing strange. One socket pin wasn't in contact with the cpu pin which was surely one of the important IMC contacts. As I said before, you can resolve this problem with the tooth brush method. Been there, done that (I know for 4 cases of that).
the waterblock cost $140 bucks? holy :banana::banana::banana::banana:.
It has nothing to do with resurrecting a thread, it's where you are and are not allowed to sell hardware. There is a classifieds section for a reason - I believe that part the ToS you agreed to when you created your account here outlines specifically that you aren't to attempt to sell things outside of the classifieds.
I was simply warning you that attempting to sell hardware outside the classifieds can get you banned - I was trying to do you a favor. I don't really care, I'm not going to buy it.
