Um, ok. I will try what you are saying.. Thanks for the input.
Aha!! you are the person I've been looking for:D Prime95 is my stability standard as well.
I don't have your knowledge of what the errors mean and what to adjust when you get them in prime95. Where can I learn more about this?
I'm just getting started with this board and a B3 Q6600. I was running at 3.6GHz with prime95 and I ran two of the four cores for over 8 hours with no errors, but the other two failed after an hour and half or so with an incorrect returned value. I can't remember the exact wording of the error. i know it wasn't the rounding error message. Any ideas?
Hmmm but you said above "Im now using the 400strap with my PC8500 ram operating @ DDR1130 with transaction booster enabled to "1" no way could I get this speed using the 266 strap, none the less with enabling transaction booster My latency with timings at 5/5/5/8 is 49ns" and now you're saying/showing 49ns but with your RAM at 1215MHz and a FSB of 506MHz.
Contradiction somewhere?
You're reading the wrong post sir. I never stated that, the other gentleman (newls1) did. What you see there are my settings.
Misread somewhere?
Any thoughts on this
http://www.xtremesystems.org/forums/...&postcount=216
Is this simply a driver issue or is it related to the soundcard and OCing?
This is what I found out with my testing: NOT ALL rams work well on the 266 strap. my Corsair Dominators (Rated at 1066mhz) can do 1300mhz on this board, but on the 266 strap, it won't post past 8x470fsb.
Now, my Team Xtreem rams are rated at 800mhz, but can also run at DDR2 1300mhz. It can also run above 470 fsb to about 495 fsb (I believe my quad is the bottleneck here). Here is the Team ram, doing 8x475 on the 266 strap 5-5-5-10-25-3-3 @ 2.24v. You need the right memory - those rated for CAS 4 (I believe), and then you'll be above the clouds in 266 heaven :D
Edit: I didn't take it to DDR2 1200 because there is a latency change between 475-480 fsb which leads to about 1 latency higher @ DDR2 1200.
Bump :D
Anyone here could do me a favour if possible? Has anyone managed to make a recovery disc in Vista SP1 using the new maintenance feature? I'm in Sweden at the moment and desperately need to use startup repair on my Vista partition to fix an MBR problem, but I am only on limited internet access at the moment.
It would be gold if someone could help out!
P.
Hello,
Renegade5399, I came to Bios 802. My final settings are:
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 440
FSB Strap to North Bridge : 400
PCI-E Frequency: 110
DRAM Frequency: Auto = Otherwise unstable
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 12
RAS# to RAS# Delay : Auto
Row Refresh Cycle Time : Auto
Write Recovery Time : Auto
Read to Precharge Time : Auto
Read to Write Delay (S/D) : Auto
Write to Read Delay (S) : Auto
Write to Read Delay (D) : Auto
Read to Read Delay (S) : Auto
Read to Read Delay (D) : Auto
Write to Write Delay (S) : Auto
Write to Write Delay (D) : Auto
DRAM Static Read Control: Enabled
Ai Clock Twister : Strong Relax = 0
Transaction Booster : Disabled
CPU Voltage : 1.4937
CPU PLL Voltage : 1.6
North Bridge Voltage : 1.49
DRAM Voltage : 2.2
FSB Termination Voltage : 1.4
South Bridge Voltage : 1.1
CPU GTL Reference : Auto
North Bridge GTL Reference : Auto
DDR2 Channel A REF Voltage : DDR2_REF
DDR2 Channel B REF Voltage : DDR2_REF
DDR2 Controller REF Voltage : DDR2_REF
SB 1.5V Voltage : 1.5
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED : Enabled
Advanced CPU Configuration
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Enabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Disabled
I blocks to 3960 MHz. I would like to happen as you exceed the cap of 4GHz.
Greetings from France
Thanks for your opinion
MARSOUIN:
Set this to auto.Quote:
Then pick a speed you know your RAM can handle. Shoot low for now. You can up it later.Quote:
Try setting Relax to 1 if you're having stability issues.Quote:
Set to around 1.52Quote:
Set to 1.5Quote:
Try that and see what that does for ya.
WOW 0907 is out
Yes. Read a feedback at forumdeluxx.de that says, that QFan runs better now. Another user flashed from 0903 and his OC settings are even stable with 0907.
Will try it today evening.
change log for 0907 surfaced yet?
I'll give it a test as soon as I can drag myself away from the CTRL+ALT+DEL archive...
Guys Bios 0907 is up on the ASUS site. I am going out to the football now so cant test yet. Antone testing please report results back here. Especially Quad FSB clocking and wether the straps are working correctly.
Cheers
CPU temperature is 20° lower than before. 5°CPU in Bios.... first little bug. Settings for 450x8 from 0903 seem to be stable after a short test, no changes there.
Hi, as eSp!s0 has pointed out, the CPU calibration is back to the 'traditional' asus way of reading the CPU temp. Please note that with this reading it is taken from a external diode, that is why the core temps are higher. Comparing my temps, CPU in Probe says 20c, coretemp says 34,34,30,32c...
Chris
