the lace don't fit in the case. :(
very clean system. :up:
lace? what lace?
patriote change that urine looking color green to blue will look much much better :)
*tryingtothinktypicalgerman* :p:
Imho he mean the cable fixers around the tubing, or the tubing himself..
http://dict.tu-chemnitz.de/dings.cgi...vice=&comment=
:slapass: @ dictionary.. :p:
yeah.. in the open case pics the white ties do stand out a bit. but its not as bad in night pic with case light... maybe u can find some red ones, or paint the white ones red.. experiment - u might find something that hits a spot with u!
edit: hang on a tick, r u using them to clamp the tubes to the fittings? not interested in these?:
http://www.petrastechshop.com/ststwohoclwb.html
i reckon these might give ur set-up a 'industrial-heavyduty' look to it :D.. dunno, just an idea :up:
i took simply the first word from the dictionary and “lace” was the first. :owned:
that is only the german way of thinking. :yepp:
The flow may look OK with the small round interior of the res but I wouldn't be the least bit surprised if it was under 200 LPH. I sure hope that's a 18W pump, otherwise, your probably under 150 LPH.
The AGB res has been shown to hurt flow as shown in this topic here. The BI GTS is also known to hurt flow, mixed with 2 other rads (which are basically 4 90° elbows with thin tubing between them) as well as the blocks and you have a low flow/low pressure system. I recommend you add another pump of the same wattage and remove the AGB and add a Swiftech micro res (<-preferred recommendation) or lose at least one of the rads (preferably the GTS) and shorten the loop a little.
IMO, the best setup would be a single rad using either a TC PA120.3 or a Swifty MCR320 up top, but I'm not suggesting either of those because I know LL's aren't cheap and I'd hate to see it cut up any further, as it may look fugly if you do.
http://i203.photobucket.com/albums/a..._000300011.jpg
http://i203.photobucket.com/albums/a..._000500031.jpg
Q6600 G0
DFI 680iLT
2 X BFG 8800TX SLI
OCZ DDR2 PC2-8000 Titanium Alpha VX2
Creative Sound Blaster Live Platnium
OCZ ProXStream 1000w
Tagan /\ Plus Black Pearl
Apogee GT, MCW30, MCP355 w/Petra'sTech DDCT-01s Top,
Thermochill PA120.2
