nice CM Rulez
here goes mine:
http://i53.tinypic.com/e7zayo.jpg
nice CM Rulez
here goes mine:
http://www.abload.de/img/4soou.jpg
I made a extra long fan cable. Here it is:
http://www.abload.de/img/2vtxl.jpg
http://www.abload.de/img/37rxo.jpg
The fans are powered by an Aquacomputer Poweradjust 2.
Yes, but i will replace it with a 280 to have more space for HDD etc.
http://www.abload.de/img/59r1u.jpg
@xFEARx3 i was wondering what kind of temps you would get from running just LT with that set up
LT... hmmm??
this is what you have right?
Watercool MO-RA3 4x180 LT ?
Ahhh.. I have the pro Edition. But without the 420, there would be ~2° difference.
xFEARx3, awesome setup,
could you just tell us what liquid you are using?
the blue color is awesome !
also what kind of tygon tubing you are using?
Thanks..
System Spec:
Coolermaster ATCs 840 Chassis x2
Intel X5650's
EVGA SR-2 Motherboard
EVGA GTX480 Hydro Copper FTW (4 way Sli)
12GB Crucial RAM
Kingston 64GB SSD's
Coolermaster Silent Pro Gold 1200w PSU
Watercooling Spec:
MIPS MB and RAM Freezer Blocks
Watercool HK3 CPU Blocks
Bitspower Carbon Black fittings
Phobya Radiators (2x 480 & 2x 240)
Koolance RP-450X2 Bay-Res x2
Laing D5 Pumps x3
http://www.coolercases.co.uk/evga_sr-2/840_sr-2_26.jpg
http://www.coolercases.co.uk/evga_sr-2/840_sr-2_21.jpg
http://www.coolercases.co.uk/evga_sr-2/840_sr-2_6.jpg
http://www.coolercases.co.uk/evga_sr-2/840_sr-2_3.jpg
coolmiester I think this one is far your best work... Outstanding mod skills you have, I just wish you were my next door neighbor so I can watch your mad skills in person.. :D
only one 360 rad for 2 GPU + CPU + MB + RAM Waterblocks? o_O
Can you give your load temps?
I don't think I ever posted my corsair 600t rig ...
you can view the build log/parts here :
http://vivithemage.com/2011/04/water...-2500k-2x6950/
http://vivithemage.com/zen/albums/vi.../P1000123a.jpg
to Junkun13.,hi there.,can i know where u bought the white coolant.,may i know the brand..tq
I think it's..:
http://school.discoveryeducation.com...mages/milk.gif
I like the color theme junkun :up:
@Junkun13:
What liquid is that additive?
Regarding the temps, they are quite hot, cpu idles at 38º-40º while gpus minimum is 39º-45º maximum at 73º-81º
I'm okay with the temps as long as my system is beautiful and the temps are still acceptable since I won't be doing any overclocking
@junkun is that a triple 120 or a triple 140 rad? your build looks amazing. if only the temps are a bit better :)
junkun13, i hate that case, but that is masterful work.
