Any Ideas, New LT P35 will not boot into Bios
To Praz,
I just tried to boot up a new LT P35, the one in my signature works fine.
This new LT-P35 was going to replace a P965 Dark as my test machine.
Anyway I plug 2 X 1Gb sticks of Memory Corsair DDR 1066, 1 Video Card (7950 GT) the Q6600, a mouse and keyboard, switch on the Power and no Boot.
Normally you get that false start on my other DFI Boards but not this. The error code showed what looked like a '40' error for missing floppy, but the LED was not clear.
I cleared the CMOS and removed the batteries and put the Battery back, changed the pins back to the 1/2 position. The Clear was all of 30s.
Initially I thought dud Q6600, but I swapped out the MB and the P965 Dark boots with all the components listed.
Power Supply (P&C 750W) to the 24 pins + 8 pin and the 2 X 4pins slots near the PCIE.
OK this is what I noticed, with 1 stick of memory, the DRAM led light does not Light up, so in your opinion is this an RMA job. Incidently the DRAm led light is lit in my UT P35.
