my D975xbx2 setup is killing my soul
Hi everyone. I cannot for the life of me figure out why my computer will not post, so this is a last resort (before I kick the computer in the face and buy all new parts). ANY HELP is much appreciated!
Here's the background:
I have owned this setup for a little over two years now. Had the occasional BSOD, but only because of some OC (E6600 @ 3.4Ghz). I never bumped CPU voltage past 1.4 and my Tuniq kept temps in the 30-40's.
One day, a month or so ago, I installed a bunch of driver updates without restarting in between each one, and then I did a bios update. The updates appeared to be successful, but then on the NEXT reboot, my system wouldn't POST. When I press the power button, the comp will seemingly turn on (all fans go 100%, then slow down a bit to "normal speeds"), yet I see no video. First I thought it was the RAM, so I tested something like 8 other sticks, and because it still happens I assume it's not the RAM. I then RMA'd the motherboard, but that didn't yield any new results. I just bought a used, known-to-be-working video card, and that also doesn't work. The only things I have plugged in are my Mobo, CPU w/ stock intel fan, 1 stick of compatible memory (tried 2 as well), my GPU, and my monitor (which I know to be working) to the GPU. SAME THING!
I initially disregarded my power supply, because it seemed like the most reliable part (corsair hx620w), and my system "powers on", but is it possible that's it? In the past, if I didn't have the PCIe power port plugged into my graphics card, the system would still boot (but the bios would tell me I need more juice), so I can't imagine it's the PSU. I DO have the 8 pin motherboard power cord and the 24pin plugged in, and I have tried with and without the extra molex power port on the mobo.
I tried powering off and removing AC cord, removing CMOS battery, letting sit for a while, and plugging everything, but that still doesn't work. I tried simulating a failed CPU by removing it, but the system won't even power on without a CPU, so it's not that either right?
I am at a complete loss here, and Intel doesn't know either. :shrug:
