I also got my 5400UL rev 1.5... but its rated for 3-3-2-8 would that be bad?....... its still fat body....
http://img.photobucket.com/albums/v3...e/DSC00242.jpg
Ok no problem :)
source: http://www.houseofhelp.com/forums/sh...d.php?p=198002Quote:
Corsair:
This change is effective immediately. Parts with the revised specification will have a specification number of XMS5400v1.5.
This change was made due to a subtle change in the performance characteristics of the RAMs used to build these modules. While the XMS5400UL modules typically continue to function at the 3-2-2-8 latency setting, they will no longer pass Corsair’s rigorous qualification with those settings, and may not demonstrate long-term stabilility.
So they are worse :slapass:
actually: no .... they are still the old :D but not in corsair's eye. All 1.2 and 1.1 that still were @ corsair are spd edited (3-3-2-8 instead of 3-2-2-8) and relabled @ hs (v1.5) ...
my fat body d9 :(
http://img159.imageshack.us/img159/6403/img43289dk.jpg
WTF OMG......... how did you do that?????? you didnt used a bank pass or something, just pulled?
waus-mod: Don't worry the 1.5, here it is my 5400UL 1.5 on P5WD2-E(no mod),
I think it is not bad.
1.8V 800 4-2-3-4-2 hyperpath3=ON
http://static.flickr.com/46/117248804_48305236d4_o.jpg
2.4v 1000 4-2-3-4-2 hyperpath3=ON
http://static.flickr.com/56/117251083_79f4aca9b0_o.jpg
2.4V 1080 5-3-3-4-2 hyperpath3=ON
http://static.flickr.com/39/117248803_58fde09c48_o.jpg
:eek: :eek: :eek:Quote:
Originally Posted by C_B
extreme:stick:
glue them back:slap: :D
I removed a lot of HS from more than 20 BH5 RAMs ....
but this fu**ing stuff, it gone so easy :(
it was cheap RAM from ebay so I´m looking for a new 2GB Kit ;)
What is brand of these ?:(Quote:
to bad cb,
next time use a bank pass for safety!
autsch again....Quote:
don't waste your money in destroying hardware
ok, i have said ... "the mods will do the rest"... so i think a nice v-mod must be doneQuote:
Originally Posted by M.Beier
yep ;)Quote:
Originally Posted by Waus-mod
CM2X512A-4300C3 -- XMS4303v1.1Quote:
Originally Posted by kone
with Micron D9CRZ ICs
good luck for search in ebay, ........
I´m asking RumGuy from houseofhelp ,
the newer one don´t have this ICs ...
singelchannel is cool (one stick):D
what is the multiplier range in ES (Dothan and Yonah) ??
The same as with non-ES. Which means 8X up to stock if I'm correct.Quote:
Originally Posted by yotomeczek
Someone knows where I still can get those Corsair 5400UL's? I prefer in Europe ;)
(Otherwise I'll just take the cheap ones and hope I'm lucky)
Or other suggestions? 1gig will do fine, somewhere around €160-180 would be ok
Originally Posted by easypanic
Ι have,......:D
Maximizer in da house....:D
Just do a direct rail mod from 3.3V line :p: :D
one question regarding the rams again :)
Since i'am an amd guy atm i want ot know how 4x512mb work. Is it same thing as on athlons (2T command) and if not will 4 sticks clock as if u use 2 ?
Last pentium was p3 450 ;)
Nope, 4x512MB works fine and clocks just as well (in fact on my p5wd2 my max benchable on the mem went up 8MHz with 4 sticks).Quote:
Originally Posted by ic3m4n2005
6x should be. The battery saving clocks in all those benchies was at 1000MHz/6 = 166MHz FSB.Quote:
Originally Posted by alexio
lolQuote:
Originally Posted by Bogi
even better then a Banias ;)
