sweet - that is the cpu I plan to get too :rocker:
I was reading the ol' super pi mod thread today, and everyone had wicked times on SD's with vapo.. and I'm wondering if anyone would know off the top of their head if my chip will cold bug? It's KABYE 0536 GPMW.. How would I test it to see if it'll bug? I don't know anyone with a phase change..
Maybe it will, maybe it wont. YE chips are still light years better off than 2E etc. chips.Quote:
Originally Posted by haveblue
Well I dont get it this is as high as I can get mine. Did I just get a really bad chip or somthing? Or is it somthing else like my motherboard?
http://i21.photobucket.com/albums/b2...zeWizard-1.jpg
I was thnking about getting a DFI but I'm not sure if I would really know what to do. Im too lazy to take off my hsf and look at it to see what stepping it is. I will sometime though.
Hey guys what do you think of this 3700+ steping ? KAB2E 0538BPMW
My 0547GPAW a little better on WC now:
3100MHz prime95:
http://img374.imageshack.us/img374/4...2mhz2dm.th.jpg
3190MHz SPI 3190MHz:
http://img149.imageshack.us/img149/4...pi1m5pg.th.jpg
Not optimized yet.
Cheers Monge
Could you guys help me? How are people getting 3000mhz+? I tried to go 255x11=2805 with 1.65 volts and it willn't even boot. Wtf is wrong? Is it my motherboard? I have the evga nforce 4 Sli motherboard.
Have ya checked all the obvious stuff like HTT multiplier, RAM settings etc etc?
Whats your full system spec? Decent PSU?
K
Whats the TDP and TCM of your chip? That should give us some clues.
http://www.thecoolest.zerobrains.com...topic.php?t=83
higher=better OC potential, although generally higher temps
Well here are my system specs
3700+ (duh)
1gb DDR400 cheap memory
evga 7800gt
480w thermaltake silent purepower (is the powersupply not good enough?)
Thats the main stuff.
Well the memory is on a divider running at 196mhz the timings are 3-3-3-8
I have the HTT multiplyer at 3 so thats not the problem. I havent tried it at 1 or 2 yet though.
Im not sure what you mean by TDP and TCM. Here is a screenshot of that program though
http://i21.photobucket.com/albums/b2...omeprogram.jpg
Honestly, I think it's your mobo. Have you tried using ClockGen to crank the clocks within Windows?Quote:
Originally Posted by The Amish Kid
DFI would be the quickest fix for this problem IMO.
I'm kind've dissapointed right now.. just moved up from stock to a Freezer 64 Pro, was hoping to get a bit of a gain.. nothin' though.. I tried for 3.1ghz today, but no luck, instant bluescreen (was working with clockgen).. Not sure what caused it.. Temps were not great by any means, but were not terrible.. ~40C.. Voltage was enough to be 1m pi stable (not stable lol) at 3.0.. but, I'm scared to crank them up any higher.. they were at 1.525 + 110%.. Any suggestions?
Sorry to double post but....
Does anybody have infos about the KAB2E 0551UPAW ?
Thanks.
@ the amish kid: 36sec 1M spi is pretty bad at that speed i think.
i think the fault is in the memory. if its not capable of running cas 2.5 at 200mhz, then u got really to ask urself what crap u have sticked in the mobo.
for example, i managed to beat 32sec 1M spi out of a venice 3000+ 0523 with kingmax hc 2x512 @ 310 3-4-4-8 2T
cpu @ nearly 20°C
http://membres.lycos.fr/starostise/K...C_cpu-3521.PNG
it can do better :)
Wow! What cooling do you have on that thing?
i putted my dod, turned on then turned off to increase temp (coldbug)
i could not valid this score, too late, it has rebooted :(
Yeah I know, its kinda hard to afford all the best stuff when you are only 14. I have gotten the time down quite a bit now. It can run cas 2.5 at 200mhz just I wanted to make sure it wasnt my memory holding me back. Here's the best I can get thoughQuote:
Originally Posted by b1tterman
http://i21.photobucket.com/albums/b2...2806mhz-32.jpg
I must have got a complete crap one. I can only get 2.8ghz with 1.65vcore. I havent took off my hsf to look at the stepping yet though.
CCBWE 0541XPMW
Is this good stepping and does it have coldbug ?
Sweet CPU, wish I had that one :(
amish kid I would say that your mobo is holding you back, but you could try a lower divider on the ram.
The single channel RAM is killing your performance. Time for better RAM. ;)
i have a 3700+ here, ill check it and see what she is
dualcore. can probably go down to -20°C. You can only find out yourself.Quote:
Originally Posted by Revage
whats your multi, because your running 311fsb, sounds like 9, drop your fsb then put it on an 11 multi, and start working back upQuote:
Removed IHS from my Sandy CABGE 0515 SPMW, and gain 20c at full load.
2.9Ghz prime stable@1.58v.
