Originally Posted by alpha0neSame ram but different motherboard but it should give you some idea :)
System -- alpha0ne
Opteron 170 CCBWE 0546XPMW
10x280 2.8ghz @ 1.488Vcore / 1.51v Shown in Bios
DFI NF4 eXpert Bios NF4EDC07 / X850XT
2x1GB Gskill 4000 HZ 1:1 @ 280MHz 1T 2.67Vdimm / 2.71v Shown in Bios
2xHitachi 7K80 SATA II Raid 0 + 1xWD1600JB + 1xWD800JD
Memory Bandwidth (memtest 1.65) @ 280MHz = 2881MB/s
OS--- XP Pr0 SP2
VID= 1.475
VID SPECIAL= 102.4%
CHIPSET= 1.50v
LDT= 1.2v
LDT= 3
CPC = Enabled
CAS Latency(CL) = 3
RAS to CAS(Trcd) = 4
Min RAS# Active time(Tras) = 7
Row Precharge Time(Trp) = 4
Row Cycle Time(Trc) = 12
Row Refresh Cycle Time(Trfc) = 14
Row to Row Delay(Trrd) = 3
Write Recovery Time(Twr) = 2
Write to Read Delay(Twtr) = 2
Read to Write Delay(Trwt) = 3
Refresh Period (Tref) = 3684
Write CAS Latency(Twcl) = 1
DRAM Bank Interleave = Enabled
Skew = Auto
Skew Value = 0
DRAM Drive Strength = 7
DRAM Data Drive Strength = 1
DDRAM Response Time= Fast
Max Async Latency = 8
Read Preamble Time = 6
Idle Cycle Limit = 16
Dynamic Counter = Enabled
R/W Queue Bypass = 16
Bypass Max = 4
32 byte Granularity = Disabled
I will give it a try...thank you!
