Got one last test for you all
S&M 1.7.2 (maybe newer versions will do this)
Start speedfan, etc first so you can monitor what is happening.
Run the power test and wait for 6 mins, then watch what happens during the VGA test (go to monitoring tab). You will have to prolly have to keep hitting the reset tab to keep it going. You may find that it disappears when hitting this part of the test.
This was what happened when testing a new chip that I got last Thursday.
This test was after sucessfully running large FFTs using 865mb apiece for 10hrs and OCCT on the 'weak' core for a few hours, when S&M on both cores for a run (after I got past the VGA test, the mem stuff was a breeze).
Also, ahs anyone actually GOTTEN OCCT to run @ 2 instances at the same time? :confused: )
Had to knock Vcore up a notch or S&M would disappear @ VGA test time. After I got it stable (meaning no bybye here) CPU went from 35->38c and PWN from 44 (2x D2oL now) to 55c :shock:. But I know it is working now.
Got to get some more candies up for D2oL, so will try some other stuff next week.
