http://img480.imageshack.us/img480/6...kukt5wb.th.jpg
[hwbot]Conroe 6700 ES @ 3.7ghz Zalman 9500, 1.50V, X1900 Crossfire @ 660/770 stock coolers[/hwbot]
http://img133.imageshack.us/img133/3...ark20054bd.jpg
.......edited
[hwbot] 20803 - Core 2 Duo E6700 ES @ 4050mhz , 7950 GX2 @ 725/1610 [/hwbot]
http://www.vmodtech.com/files/05_152.jpg
I edited my post because i'm unsure if I can just join the team? Or can I just post away?
[hwbot] 450tantrum - 11000 - Opty 144 @ 2.83 | 7900GT @ 690/1800[/hwbot]
http://service.futuremark.com/compare?3dm05=2026728
In principle one can post results for many teams (fora), but this is definitely NOT encouraged. If you want to remove your scores from guru3D, the easiest way is to remove the score lines from the posts you made there.Quote:
Originally Posted by CraptacularOne
Yeah I deleted my scores over there. The admins over there are a bunch of :banana::banana::banana::banana::banana::banana:sQuote:
Originally Posted by mtzki
^ you can say that again
but hey admin. my 11k score still isnt up, i should #106 ;)
[hwbot] rob[GL] - 20801 - Intel Conroe @ 3.75GHz X1900XT Crossfire 756/828 [/hwbot]
http://img.photobucket.com/albums/v3...wm21/20801.jpg
nice background :)
Putting your nickname between the tags is no longer required by the way.
good: [hwbot] score - description [/hwbot]
bad: [hwbot] nickname - score - description [/hwbot]
[hwbot]13871 - AMD64 170@3061MHz - X1900XTX@755/860[/hwbot]
http://service.futuremark.com/compare?3dm05=2135452
:D
[hwbot]9431 - Intel C2D E6400 @ 3552Mhz - 7800GT 256MB @ 551/592Mhz[/hwbot]
http://service.futuremark.com/compare?3dm05=2140419
[hwbot] 18578 - Intel Core 2 Duo E6700 @ 3.6 GHz - 7950 GX2 @ 603|800 - aircooled [/hwbot]
http://img58.imageshack.us/img58/2599/3dmark05tn7.jpg
3dmark05-18578
http://service.futuremark.com/compare?3dm05=2143079
[hwbot]14049 - AMD64 170@3050MHz - X1900XTX@776/868[/hwbot]
http://service.futuremark.com/compare?3dm05=2147988
[hwbot] fhpchris - 12291 - Intel T2600 @ 3030 MHz X1900 ALL IN WONDER 680/666 [/hwbot]
http://service.futuremark.com/compare?3dm05=2152207
http://www.sspmustang.com/OT/3d05%20tweaked.JPG
[hwbot] Vett95wlt4 - 18656 - 7950 GX2 @ 602/784, C2D X6800 @ 4200 mhz[/hwbot]
http://service.futuremark.com/compare?3dm05=2153996
EDIT:Double post
hwbot] 14832 - E6600 @ 3780 , single X1900XT @ 732/846 [/hwbot]
http://www.crazypc.ro/forum/attachme...8&d=1155250376
[hwbot] 12269 - AMD64 X2 3800 @ 2900, single BFG 7900GT @ 740/1920 [/hwbot]
http://service.futuremark.com/compare?3dm05=2157138
[hwbot] 18563 - Core 2 Duo E6600 ES @ 3870mhz , 7950 GX2 @ 622/1436 [/hwbot]
http://service.futuremark.com/compare?3dm05=2151555
http://img228.imageshack.us/img228/1777/05ocmb9.th.jpg
[hwbot] Unrealer - 8636 - Venice 3500+ @ 2420mhz - Asus 7800 Extreme @ 525(+70)/1350 vmod 1.70v[/hwbot]
[hwbot] 10812 - Core 2 Duo E6600 ES @ 3870mhz , 2x 7300GT @ 592/1554 [/hwbot]
http://service.futuremark.com/compare?3dm05=2175324
